don't stop the fan
08.05.2020 19:25 # 1
srhtswr
Hello friends, good luck to everyone, I have a few questions for you
my car 206 gti s 16 model 99 model questions
-It seems like it will stop eating gas when it starts first, but it recovers after 3 5 seconds.
No problem when the vehicle is cold, but the engine stops when I start warming marsi 2. In the 2nd edition, the fan does not start at the required temperature (water temperature changer changed)
-Car exhaust from the exhaust smells of gasoline, but there is no white smoke.
-Brain malfunction, brain was repaired
I would be glad if friends who know the reasons of these write srhtsw is 2015-08-19 12:13:43
08.05.2020 19:25 # 2
GokhaN
if there is a problem with the fan it is probably an electronic problem
08.05.2020 19:25 # 3
srhtswr
I don't think it's the only reason
08.05.2020 19:25 # 4
Turgay_66
1.clean idle valve
2. It is most likely that it will stop at vehicle temperature from the idle valve.
If the 3rd fan does not start at the required temperature, change the fan resistance (on the front of the radiator)
4.Check coil and spark plugs for smell of gasoline
I hope it will recover soon.
08.05.2020 19:25 # 5
srhtswr
Thank you bro, I will try what they say, only a piece of water with a long dome on the top of the coil, and a new one was installed.
