don't rub my head
08.05.2020 16:52 # 1
GiTaRRa
friends my previous tires 185 55 14 but my tires 185 55 14 ee did not change, but the rear is rubbing badly. not the person & nbsp; even the person is rubbing what I have to do .. the tire size is the same but the previous tires were like thinner cheeks would it have something to do with it? Both of them are the same size, I can't get this rubbing thing to my vehicle & nbsp;
08.05.2020 16:52 # 2
EmSul
Is it only tires changed or changed on wheels?
If it has changed on wheels, it may be due to offset ..
But if it is the same on wheels, it is the model of tires ..
08.05.2020 16:52 # 3
GiTaRRa
wheels were with previous offset, now GTI rim, so my previous rim had no friction ..
08.05.2020 16:52 # 4
EmSul
every rim has an offset that matters the value of the offset. So the offset of the GTI rim does not match your 106, with the GTI n rear mudguard, yours is a different mudguards or rim replacement.
08.05.2020 16:52 # 5
GiTaRRa
If it makes sense to operate in the fender, what kind of operation it requires makes me think of removing it anymore ..
08.05.2020 16:52 # 6
EmSul
You must swell the fenders open. I think change the rims ..
08.05.2020 16:52 # 7
KenBlockJR
If you install a spacer (flange) it can be resolved. if you want a search
08.05.2020 16:52 # 8
ufuk91
If your wheels are not very new, I think you should get a thinner tire on the cheeks. If you have a rubberman you know, replace it with a lower tread of the same quality, if you can match it, something clean.
08.05.2020 16:52 # 9
superyusuf
I have friends mrb.106, I bought a 206 cc rim, I wore a 195/45/15 tire.It got a rubbing on the right back.I got a person on the top.It rubbing to the top of the body.It leaned the inside of the body of the body.I still got it. rubbing. Why would you help?
08.05.2020 16:52 # 10
GiTaRRa
previous 185 55 14 but it looked like a thin cheek tomorrow my first job would be to go ask the tire tire because there was no rubbing on that tire
