Don't put my foot on the gas
08.05.2020 21:14 # 1
cagdasnas
Hello friends. I just registered for the forum. I have 206 diesel 2006 model vehicle. I just bought the vehicle. When I press the gas and take off my foot, the car suddenly seems to brake. It doesn't bother much, but I did an obsession. We went to the master, the lower motor ear has changed, but the problem persists. What do you think could be the problem? When I take my foot out of the gas, it beats like an engine brake.
08.05.2020 21:14 # 2
First of all, welcome to us. I sent the answer you wanted specifically, brother.
08.05.2020 21:14 # 3
kod06
Hodja, good evening, I have this problem. I wonder if you can help me too. Thanks in advance Smile kod06 2019-07-15 23:11:00
08.05.2020 21:14 # 4
kod06
[QUOTE = sonerkyl] First of all, welcome to us. Specially, I sent the answer you wanted, brother. [/ QUOTE]
08.05.2020 21:14 # 5
OguzhanKucuk61
Tell us so we can know Soner brother LOL
08.05.2020 21:14 # 6
ibrahimyank
I also suffer from the same problem, and while doing this, a sound like vik vik sounds as if something is playing.
08.05.2020 21:14 # 7
alixx35
Hi;
The same problem I have in my 307 1.4 hdi vehicle for 4 years no one has not changed We have not changed nothing left
When I give my foot on the gas, it shakes, wedges, injectors, clutch lining
Whatever has changed, can you help me.
alixx35 2019-09-17 18:42:47
08.05.2020 21:14 # 8
cadde40
mrblar 307 1.6 hdi 2007 My feet in a 90-hour cruise
When I pulled out of the gas, it knocked and when I pressed it.
no sound, no startle, no sadexe driving comfort
you sent a private message bized3 can you help
print lining timing engine transmission wedges etc. always changed
reacting while gasing or pressing my foot
just at that moment when the tachometer knocks out the titry please
I'm waiting for your urgent help
08.05.2020 21:14 # 9
cadde40
please send it to us
08.05.2020 21:14 # 10
emrahi
If the format of the site has changed, sir, I would try to get information by reading the new topics and opening the site once in every 3 or 3 days.
08.05.2020 21:14 # 11
cadde40
[QUOTE = emrahi] Has the format of the site changed hojam, no matter whether or not I would open the site every 2 or 3 days and try to get new readers 5 information. [/ QUOTE]
I do not know the format has changed etc. Soner Bey has solved this problem but I hope that he could not reach the forum.
08.05.2020 21:14 # 12
Your friend was very bored, gentlemen can cause this type of problems in the engine of the vehicle. one of our members even said that there is such a problem in 1 gear. If you root the gas in 1 gear and pull your foot, this situation is quite normal.
Nowadays, I can not spare a lot of time due to work intensity. Smile do not be sorry
sonerkyl 2019-09-18 09:46:10
08.05.2020 21:14 # 13
cadde40
[QUOTE = sonerkyl] Your friend was in trouble, guys. one of our members even said that there is such a problem in 1 gear. If you root the gas in 1 gear and pull your foot, this situation is quite normal.
ok soner expect your help 2 friends from this
complain will fix the problem of construction
08.05.2020 21:14 # 14
cadde40
[QUOTE = cadde40] [QUOTE = sonerkyl] Your friend was very troubled, guys. one of our members even said that there is such a problem in 1 gear. If you root the gas in 1 gear and pull your foot, this situation is quite normal.
I add 1 and 2 gears in the presentation 3 4 5 does not make very very significant acceleration
when the vehicle presses the gas,
08.05.2020 21:14 # 15
krowne
I am wondering why this problem is going to be shared with me. When I take my foot off the gas in 3rd gear, the car slows down as if I am braking
08.05.2020 21:14 # 16
cadde40
[QUOTE = krowne] I am wondering why this problem is going to be shared with me. When I take my foot off the gas in 3rd gear, the vehicle slows down as if I am braking [/ QUOTE]
Thanks soner entered the monument 2 minutes and did not say the mistake still bkliyoz
08.05.2020 21:14 # 17
krowne
[QUOTE = cadde40] [QUOTE = krowne] I am wondering why you are sharing this problem with me. When I take my foot off the gas in 3rd gear, the vehicle slows down as if I am braking [/ QUOTE]
and we are still waiting
08.05.2020 21:14 # 18
krowne
There was a problem with the engine bottom chock, friends, I did not have one of the bolts. When the deficiencies in this section were eliminated, the motor sound became looser and the motor noise was noticeably reduced.
08.05.2020 21:14 # 19
alixx35
[QUOTE = krowne] There was a problem with the engine bottom chock, guys, I didn't have a bolt. the shortcomings in this section softened when the deficiencies were eliminated, and the engine noise was noticeably reduced [/ QUOTE]
Master, how was it not being a bolt? What bolt was there?
08.05.2020 21:14 # 20
pusutr
This problem is usually due to the catalyst filling, friends. Or there is a blockage in the exhaust system. In other words, burning fuel fumes are not released from the vehicle. To test this, run your car for 2-3 minutes and then accelerate in 1st gear and take your foot off the gas. If you observe relaxation, it means what I said happened. Of course, don't forget to have the chocks checked first.
Page : / 2
