Doesn't work on LPG and gas
08.05.2020 19:56 # 1
MetinTural
Good day 99 model 206 atiger in-line system My current vehicle does not work in what fuel gas pump changed 3 times in 1 week but I still appreciate it if you help me with respect
08.05.2020 19:56 # 2
Secks
Does it work when hit?
08.05.2020 19:56 # 3
MetinTural
No, it doesn't work if I do not work in supplements.
08.05.2020 19:56 # 4
Secks
Does the starter sound when you turn the ignition?
08.05.2020 19:56 # 5
MetinTural
Yes kirrr kirrrr kirrrr mars is printing but it doesn't work
08.05.2020 19:56 # 6
KILIC
If the lpg does not work in d, it is not from the pump. It may be from the crank speed sensor. Or they may be from insurance.
08.05.2020 19:56 # 7
MetinTural
If I guess that the Krak will be from the ansorund, the vehicle works in the lpg, but it stops when it works. It works for 1 minute. It stops. The throttle is running.
08.05.2020 19:56 # 8
Well, the injectors have been checked, do you get petrol in the engine. There may be a problem with ecu. PC was connected and checked.
08.05.2020 19:56 # 9
KILIC
As far as I understand, your vehicle does not work on both petrol and lpg. LPG also runs and then stops. The throat throttle runs when the spray is sprayed and then stops again. So gas or gasoline does not come to the car. And or the air does not enter. Check the air filter. If you write them up until now what you have done, it will be easier to guess.
08.05.2020 19:56 # 10
silverlion
First of all, Metin Bey.
I had encountered such a situation months ago. A sensor on the engine block (it must have been an oil sensor) was not working in either gasoline or gas because it was not properly seated. My advise is to check the sockets. There may be oxidation or non-contact. 2. A problem in the immobilizer system can also create such situations. I hope it will be resolved.
