Doesn't work in 306 diapers
08.05.2020 19:11 # 1
ufuk306
Hello, friends, I bought the vehicle two months ago, I just joined you but there is a problem not working in my car, there is no problem when it is cold in the morning, there is no problem when it is working in the gas, but when the car is hot or after a little stop, I can work on the gas from the gas switch to the gas, you can help if you like it. thanks
08.05.2020 19:11 # 2
talip206
Have the gas pump checked. If gasoline was traveled for a long time, the problem may have occurred. In our vehicles, the gas pump runs continuously while driving on the LPG. When the amount of gasoline is low, the gas pump cannot cool itself and burns over time. My guess is in this direction. There is no problem when it is cold in the morning, the gasoline malfunctions when the pump is heated.
08.05.2020 19:11 # 3
ufuk306
If you change it completely in the evening when the samarai under this seat is attached, I understand that the problem will be solved.
08.05.2020 19:11 # 4
vpro
Samandıra does not change if there is no problem in the gas gauge 2. If the gas pump is broken, the car will hardly start when the vehicle is cold, and the cytotopes may also be a problem. Take the vehicle to the gasoline and drive for 100 meters, then the engine is hot then try to start the car.
08.05.2020 19:11 # 5
talip206
[QUOTE = ufuk306] If we change this completely in the evening when the samarai under the seat of this salas is installed, the problem will be solved.
Yes, at the place under that seat. Gasoline float and pump do not change individually as a team. I cannot say for sure, but look. As far as I understand, it has not been completely distorted but deformed. It is not a problem when it is cold, but the problem starts when it gets hot. If you search the forum, a friend of yours would have had such a situation, the petrol pump had officially melted
08.05.2020 19:11 # 6
vpro
[QUOTE = talip206] [QUOTE = ufuk306] If we change it completely in the evening when the samarai under this seat is attached, I will understand the problem.
Yes, at the place under that seat. Gasoline float and pump do not change individually as a team. I cannot say for sure, but look. As far as I understand, it has not been completely distorted but deformed. It is not a problem when it is cold, but the problem starts when it gets hot. If you search the forum, a friend of yours would have had such a situation that the officially melted gas pump [/ QUOTE]
I don't know the two are fixed at 307, but at 206 only the pump can be replaced
08.05.2020 19:11 # 7
talip206
[QUOTE = vpro] [QUOTE = suitor206] [QUOTE = horizon306] If we change this completely in the evening when the samarira is under the seat of this salas, the problem will be resolved.
I know it is united, the part that holds the money is not a float gas pump. If he is a good master, he can solve it with minor repairs. But most do not bother says direct change
08.05.2020 19:11 # 8
vpro
Hodja do not do the vehicle lpg li pump already 50 lira sub industry I got it +10 lira labor I gave 60 paper
I think the problem is not from the pump
08.05.2020 19:11 # 9
ufuk306
It can be inserted from the pump. The samandira does not work when it knocks the car like this. As if it has some effect on the reduction of gasoline, the fuel pump falls a little when the bidet fuel pump does not work with the 150 samandira, then the gas gauge comes to a little when it starts working at the gas.
08.05.2020 19:11 # 10
fisherman
In 307, I experienced this 2 times, and in both of them I replaced the pump. I think this problem was chronic in peugeot. But if the gas tank is always nearly half full and you go with gasoline at least 20 km twice a month, it doesn't happen. That's what my master said.
08.05.2020 19:11 # 11
ufuk306
Thank you, I'm going to change the pump.
08.05.2020 19:11 # 12
talip206
[QUOTE = ufuk306] The pump can be inserted from the pump. When the vehicle hits this way, it does not work as if it has some effect in the reduction of gasoline. The fuel indicator decreases a little when the bidet fuel pump does not work with the samandira around 150, then it comes to its own slowly [/ QUOTE]
Yes, the original price of the pump is sold for around 450 lira and 150 lira of sub-industry. I hope the problem will be solved. If you share it here, the result will be useful.
08.05.2020 19:11 # 13
ufuk306
I share but then I found the piece for 250 lira. There is a shortage of torsion.
