Doesn't eat gas
08.05.2020 17:24 # 1
Ultramen
Hi & nbsp; car 306 1.6 XN Gasoline / LPG The problem with the 1998 model car does not eat gas in 1-2 gears, sometimes in 3 gears, then it is thrown at the same time as the automatic gear shift, it does not notice gasoline or LPG in both. & Nbsp;
Spark plugs on Saturday The air filter, oil, oil filter has changed, the throttle is cleaned. The situation is ongoing, a master says we need to replace the spark plug wires and the ignition coil. Let those with knowledge help.
Ultramen 2013-03-11 13:22:11
08.05.2020 17:24 # 2
Ultramen
No one to help? Will the problem be solved if I replace the ignition coil and spark plug cables?
08.05.2020 17:24 # 3
Ultramen
[QUOTE = Ultramen] no one to help? Will the problem be solved if I replace the ignition coil and spark plug cables? [/ QUOTE]
Where will "MASTER" answer my question?
08.05.2020 17:24 # 4
byx
Get well. Vehicle information connected.? If it is not connected, you will definitely check the information and find the problem, hopefully. My advice is to replace the spark plug cables first. If it doesn't fix, you will have a look for other parts. Is there a place you can connect it to the other parts?
08.05.2020 17:24 # 5
ondercan
look at the spark plug wires first.
08.05.2020 17:24 # 6
Ultramen
God bless friends, connected to the computer in the private service, the fuel mixture part in the exhaust is defective, but we can replace it, but they said it will fail back after 4-5 months because you use gas. Ultramen 2013-03-11 12:36:43
08.05.2020 17:24 # 7
Ultramen
Spark plug cables were not original, I replaced them with original cables. problem solved thank you.
