Doesn't draw 206 xt
08.05.2020 14:15 # 1
Melih
hello I bought 2000 206 xt about 1 month ago, although my vehicle is 1.6, I used many 1.6 vehicles before the performance of the vehicle is low, the vehicle is drowning on the slopes and if the fuel goes as much as I burned, I need to look at what else I should have changed the oil filter and the air filter.
08.05.2020 14:15 # 2
Haci
Whether your car is auspicious or my brother has a good taste, the friends who are knowledgeable about the subject will help.
08.05.2020 14:15 # 3
F-Eren
I say absolutely replace the gas filter and spark plugs
I also have 1.6 16v 2003 automatic transmission
I changed the filters and spark plugs, the fuel experienced a serious decrease (last week I made 250km of comfort in city traffic with 80tl gasoline, the light was on, it was going to force 300).
the problem of traction on the slope is to check the throttle.
My car does not faint even when I go with the whole family on the slope and it goes as much as it burns
I hope I could give an idea
08.05.2020 14:15 # 4
arifkemal
I have 2000 xr, so I changed the gearbox valves (electrovan-solenoid valve) to the fainting fainted before changing it :) now I can't stop on the slope, it's climbing like crazy.
08.05.2020 14:15 # 5
Onur
I have 1.4 xr automatic auto throttle like cat on the climb ramp, I used 1.6 auto at the ramp, the fainting of that car can be very unreasonable in the spark plug, it is useful to have the bidet gearbox checked.
08.05.2020 14:15 # 6
Melih
sanz bakt1rmay1 think how much expense happened
08.05.2020 14:15 # 7
haruncoskun
I would also suggest you look at the extra valve settings or pushers.
08.05.2020 14:15 # 8
Onur
The daddy can cost 500 lira. It may be from the electro valve or from the heat exchanger. There is a problem with my valves. The car has dropped from the traction. Our friend Arif Kemal has made it more clear.
08.05.2020 14:15 # 9
behzat
injectors may be dirty use gasoline additive
08.05.2020 14:15 # 10
Could the clutch be missing? When you press the accelerator pedal, I think that if your tachometer increases with your acceleration but the traction remains low, your clutch lining may be missing. I suggest you have it checked.
08.05.2020 14:15 # 11
arifkemal
yes, the heat exchanger is very low, if your radiator water is not dirty! If there is rust in the parts of the water (eg radiator) then the heat exchanger is clogged, the price was around 350 TL. 179 rubles of the valves are installed in 2 units, and during this maintenance, the gearbox oil is changed, on average, it is around 450. I had the old models built at the time of the campaign. What was 310 TL? Believe me, the car has started to go. Since the gear changes in series, fuel is saved. My 10-year-old car has never changed so far, and in fact, there is no need to change it except for the uphill valves. When he's done killing, he's done. But when it changes, the helical auto is overtaking by throwing gears on the slope. It affects the traction a lot. You can have it checked for any errors by connecting it to the computer. But if not, I say it's time to change according to the age of the car ....
