Does this device work for deleting error records?
08.05.2020 17:35 # 1
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-kablo-aksesuar-elm-327-obd-cihazi-119737713/detay & nbsp;
Reviews
08.05.2020 17:35 # 2
Serkan
Yes, it clears the error codes, but if the error continues, it will light up again.
08.05.2020 17:35 # 3
hsnsnl
nice device .. if the explanation is made, i can get the knife :)
08.05.2020 17:35 # 4
Alicilik
Hello, Serkan brother even remembered sometimes even I forget. I du this device is exactly the same. It can be used in vehicles after 2002. I need to have an OBD2 socket. I do not know too much detail. There is a lot of protocol for the connection. It does not work in some OBD2 protocols. For example, this tool does not work in Opels. The main purpose of the tool is to be able to read instant data. A kind of browser sees the task. Instant speed-cycle time-temperature and pressure sensor data etc. Besides, you can search for errors and read some errors in the ECU and delete some of them. It is very easy to use; -You connect the device to the OBD2 socket of your vehicle. (In the BSI box under the steering wheel in 206). -If USB, you need to connect to the computer and select the appropriate port and establish a connection. If it is Bluetooth, you need to establish the connection and enter the bluettoth port into the program. I have a bluetooth in my car. In 206, you can close the cover while the device is attached. The same device also happened to the auris, but the OBD socket of the auris hits my leg when I plug the device outside. As a program, I use Torque software on my Android-based phone and tablet. It connects very fast and I can say it's the best software. You can also see the duration of distances such as 0-100.0-200 accelerations, 100mt-200mt. If you will only use it for error reading, you can buy a bluetooth device and connect it to each device. But if you say that I want to read the data instantly and use it synchronously with the PC, I recommend the wired one, although the technology is very advanced, the bluetooth connection does not give cable taste. They also sell at very low prices from the owner. Also this older version is now more useful than the slimmer 1.4 versions; lilar are not so long. This is the dash image of the Torque program on my tablet. It did get a little frustrating but it all worked fine when connected to the OBD.
08.05.2020 17:35 # 5
Thank you for the detailed information. I think it will be a problem for my vehicle to be 99 models.
08.05.2020 17:35 # 6
Alicilik
[QUOTE = hLL 206] Thank you for the detailed information. I think it will be a problem for my vehicle to be 99 models. [/ QUOTE]
99s know OBD1. We could not run the 2000 model 106Qs or even it did not work in 2001 206. He worked in 2006 and afterwards.
08.05.2020 17:35 # 7
Wonderful description Ali Clap
08.05.2020 17:35 # 8
ahmet_bjk
It was a nice tool ...
08.05.2020 17:35 # 9
Serkan
Good health Ali, you did not mislead you explained me in the most detailed device
08.05.2020 17:35 # 10
Alicilik
[QUOTE = koliva] Great description Ali "Clap"
Thanks Thank you brother
[QUOTE = ahmet_bjk] It is a nice tool ... [/ QUOTE]
It has a lot of functions in fact
[QUOTE = Serkan] Good health Ali You did not mislead, you explained me in the most detailed device [/ QUOTE]
You're welcome, I mean, I searched a lot at the time, but then my enthusiasm escaped.
08.05.2020 17:35 # 11
tellotello
Even if we put one of these in each car, if we connect the tablet and reach it, Smile .
08.05.2020 17:35 # 12
cerci07
This kind of devices do not work in petrol before 2004 and in diesel before 2002. I had a different model, did I know that some tools like launch creader V find and delete some errors, but I did not see some error codes. >
