Does the Peugeot 307 abs again after starting
08.05.2020 20:30 # 1
ben_erhan
Before I start the car, I turn on the ignition and wait until the lights go out .. I'm playing when the abs light goes out. After the car starts, the abs light is on and the stop flashes 3 times. . Everything returns to normal after 2 seconds .. this is always the case. Is there a problem with my car .. my car. 307 2004model 1.6 automatic gasoline. There is also LPG.
When the car is pressed, it disables some electrical parts. For example, tape.
Thank you
08.05.2020 20:30 # 2
whisky
My teacher turns off before starting and after that, it stays on our models. The abs socket or the name coming to the tire may be dusty whatever, if you have removed and installed the tire or if an operation has been done, it may be faulty, dismounted and you can try to install it again. When I made a preliminary order, rods etc. were constantly giving me errors, but when I gave gas at high speeds and braked, it stopped the error while the vehicle was idle. In short, it should not burn after the starter.
08.05.2020 20:30 # 3
akk0212
It may be due to battery weakness, a lot of current is drawn in the moment of starter, and it happens in the winter for me, it is useful to measure the battery.
08.05.2020 20:30 # 4
ben_erhan
Stop text flashes at 3 oez. Then everything is back to normal.
