Does the malfunction lab go out by itself?
08.05.2020 17:31 # 1
ahmet_bjk
Hello friends...
The engine autodiagnostic system (in the form of a fountain) malfunction lamp is on in my vehicle. When the fault resolves, does the light go out by itself or should it be cleared from the computer?
08.05.2020 17:31 # 2
cerci07
it is necessary to delete some faults depending on the fault.
08.05.2020 17:31 # 3
Mustafa-almanya
Hello my friend,
If you are talking about the engine-shaped sign, it also went out. But I don't know if it changed according to the fault.
In my Vehicle, the Exhaust System has given a warning signal that the engine is broken and the yellow warning lamp has been lit up. The car got weaker. The car's power improved when the ignition switched on and off, but the warning lamp went off after a few starts. I replaced the Diesel Filter. It never happened again.
Respects
08.05.2020 17:31 # 4
There may be two types of errors in the system. Temporary or permanent. If the temporary error is soner but permanent error, you should delete the error with PP2000 or DiagBox. Otherwise, it is not deleted automatically.
08.05.2020 17:31 # 5
Bugra
If there is no obvious problem with the engine of the vehicle, that light usually results from buying different fuels, this is what is called dirt. When it flushes out the light, it is usually a fuel related situation. but if there is a different engine malfunction, it may also warn.
08.05.2020 17:31 # 6
mstf shn
IT WILL BE REMOVED FROM THE BATTERY + POLE AND IT WILL REMOVE IF THE MUNICIPALITIES AND PLUGS ARE FAILED.
08.05.2020 17:31 # 7
samet206
I know that the malfunction lamp will not go out by itself, you have to connect it to the computer and refine the supply, and I have no other information ...
08.05.2020 17:31 # 8
emre_akdag
I think you should delete service from Diagbox. It is not deleted by itself.
08.05.2020 17:31 # 9
ahmet_bjk
[QUOTE = mstf shn] IT WILL REMOVE THE BATTERY + POLE AND WILL RETURN IT TO SOME MUNICIPALITIES AND PLUGS. [/ QUOTE]
sensible...
08.05.2020 17:31 # 10
ahmet_bjk
I have the car connected to the computer and the air flow meter code P0104 has failed. A solder was broken in the flow meter, they soldered it and deleted the fault. The next day the light came on again. We showed it to another master, he connected it to the computer and again gave the P0104 malfunction, but the master said the problem in the particle filter, not in the air flow meter. I think of cleaning the particle filter by using my vehicle at a high speed at a convenient time.
In this case, will the malfunction lamp go out by itself?
If it does not go out, I will also remove the battery + pole and try ...
08.05.2020 17:31 # 11
ahmet_bjk
Does the particle filter malfunction lamp light?
08.05.2020 17:31 # 12
cerci07
The particle filter lights up the malfunctioning lamp very often, for example, when the engine is cold, an antipollution error of over 4 thousand cycles appears on the screen and does not delete it if the filter is full.
08.05.2020 17:31 # 13
ahmet_bjk
When you clean the filter, does it delete it?
08.05.2020 17:31 # 14
mstf shn
I will talk about this with a friend and comment tomorrow.
08.05.2020 17:31 # 15
ahmet_bjk
No particle filter. I looked at Serviceboks, my car is Euro 4 and has no particle filter
