Does the information in 5664 change?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 19:27 # 1
samet2461
Friends, we bought a car 1 year ago. In inquiry, mileage information in 5664 appeared 28 thousand in 2009. 2014 grandfather appeared at 136 thousand. We changed the battery of the vehicle we bought, it was 1 year. How can this be? How to fix this. The man was madur you know.
08.05.2020 19:27 # 2
xmen
Possibly changing plate has been used before ....
08.05.2020 19:27 # 3
samet2461
[QUOTE = xmen] Possibly changing plate has been used before .... [/ QUOTE]
So what can we do? How can we solve
08.05.2020 19:27 # 4
xmen
When querying with chassis number and plate number, does the same information appear ...
08.05.2020 19:27 # 5
samet2461
[QUOTE = xmen] When querying with chassis number and plate number, does the same information appear ... [/ QUOTE]
yes, it turns out the same. I did not question with the first plate, I questioned with the chassis number, 28 thousand was out. now there are 208 thousand on the chassis with the plate. how is a very serious situation
08.05.2020 19:27 # 6
samet2461
don't you have any other helpful friends Confused
08.05.2020 19:27 # 7
themurat54
call me, or go tübtürke i think it is a really frustrating situation. What a pity
08.05.2020 19:27 # 8
pekmez006
Don't see 208 I 28. The chassis does not change, but sometimes they can make mistakes
08.05.2020 19:27 # 9
debug
Go to TuvTürk. Let them get you the exam paper of 2009, let's see if it is really 28 or 208? If you are 28, you will get a message that it is already wrong (I know that it is not possible to correct sms information) Also, it will also remove 2011, it may not have been under examination for 4 years anyway ?? If 2009 208binkm 2011 is below that (which is also below 2014) then you will be a bit of a draw for the guys. Could you get a letter that it is wrong.
In the examination in 2011, if over 208 thousand km has already been driven.
08.05.2020 19:27 # 10
xmen
[QUOTE = samet2461] Does [QUOTE = xmen] have the same information when querying with chassis no and plate no ... [/ QUOTE]
my teacher tweed search .. they will make the necessary examination and return to you ..
08.05.2020 19:27 # 11
talip206
Contact the gsm operator and request the previous sms. Time has passed, but if it is registered somewhere, you can review it again. You may have seen the first message wrong because the numbers are close to each other. If you reach the old message somehow, your problem will be solved. Since the gsm company can reach the messages in the events usually called, try your luck
