Does the battery suddenly run out? (New battery purchased)
08.05.2020 19:24 # 1
oguzhan53
Friends 10 km I came off the road, parked the car, entered the market and went out for a maximum of 10 minutes, came, started the car, clicked a dong sound and did not press it, then started it with reinforcement, but I'm still amazed how it ended when I charged it on the road. how can i get amps if i take it? oguzhan53 2015-08-13 23:09:53
08.05.2020 19:24 # 2
ahmet_bjk
When the battery wears out, it does not charge or it does not matter whether it is 10 km or 100 km.If the battery is dead, it will not charge, but if you can still use the same battery after the boost, then there may be a leak.
08.05.2020 19:24 # 3
erenahmet95
Have a look at the charger, I think. If it is faulty, it will not charge the battery and you will operate it with its own electricity. Then the battery will end suddenly.
08.05.2020 19:24 # 4
wesley09
A similar incident occurred two years ago on my 307 vehicle. When I removed the protection on the battery, I saw that the battery heads oxidized. The leak was due to the leak.
08.05.2020 19:24 # 5
talip206
Do not change the battery's amperage as much as possible. Our vehicles are already electronically sensitive. So get it from the same amperage as possible.
08.05.2020 19:24 # 6
oguzhan53
I hope there is no leak in the vehicle and the alternator is not gone. Before I go to the industry today, I will say that I will measure volts. Around 13v
08.05.2020 19:24 # 7
serdaralisan
In the measurement, 12is takes a little more battery, but since 11,70 exits, 13 of the batteries in exhausted batteries is the value of the battery that is already used, since it is 12 volts. 75 amps is a problem caused by the force of the charging adapter's excessive force. He has made
08.05.2020 19:24 # 8
oguzhan53
I just measured it gives 11.6 v. When it starts, it drops to 0.3 of course. It doesn't work. oguzhan53 2015-08-13 16:31:59
08.05.2020 19:24 # 9
serdaralisan
okay my friend has filled your battery life, it shouldn't be so low, put the original amp in the car and if possible, these cheap batteries have zero 2 years guaranteed energy flan take them from them I was using it for 6 years, did not say click th happy happy varta these would leave me on the road for 3 years then an electrician recommended me It has been working in summer and winter for 6 years. I am satisfied with the battery. I have also installed 50 amps in my car for 4 months. I did not start for 4 months.
08.05.2020 19:24 # 10
Faruk
[QUOTE = oguzhan53] Friends I came 10 km off the road, parked the car, entered the market and went out for a maximum of 10 minutes I came, I started the car, clicked a dong sound and did not press it, then started it with a reinforcement, but I am still surprised how it ended when I charged it on the road. There are 66 amps of the same size in th battery, how can I get it? [/ QUOTE]
I buy a new peugeot brand battery every 2.5 years.
For some reason, the warranty always ends, the battery runs out, the guys have set it up.
It has been 1-1.5 years now with the second one.
a little longer than you say in the incident.
I come home in the evening, my kits, such as 7-8, at 8 in the morning, the doors do not open.
The battery is dead Smile
08.05.2020 19:24 # 11
oguzhan53
I went to the industry, when I gave the old battery to the cheap battery, it was called 120 TL. let's see if the year will go oguzhan53 2015-08-13 16:39:47
08.05.2020 19:24 # 12
serdaralisan
good luck, but you have to check the battery charge continuously and do not reinforce another vehicle, it is broken. Sold in metro gros grocery stores, without the old battery, 160 tl 60 amps, old batteries do not notice broken out 60 amps 30 tl big batteries 40 and 50 tlye electricians are gathered
08.05.2020 19:24 # 13
oguzhan53
Thank you, I visited at least 6 shops and the prices are always at the same rate. I traveled with the Izmir buca industrial site and the 6th industrial site, even another vartaci said 60 amps to the battery without a deposit 195 said 20 tl.
08.05.2020 19:24 # 14
sezar206
I used the varta for 3 years, worked two times a week and mostly did not use 10 days. It went like this for 3 years. If the vehicle was used more, it would definitely go more. Bi was used in this way under the conditions of -35 degrees in the east. The last click said is dead :) Get the news that it suddenly breaks down :)
08.05.2020 19:24 # 15
oguzhan53
As you said, I'm going to end up without saying that I was never finished, the most fun part of the job was that I bought ice cream.
