Does the ballast change cause color change?
08.05.2020 17:19 # 1
Enis KORKMAZ
Hello friends, I bought xenon kit from us about 1 month ago, now the ballast has been canceled, I do not want to wait 1-2 months for a refund or something, I say I buy a new ballast directly, but I am afraid that there will be a color difference between the two headlights.
Will it affect different ballast tone? what should i do?
08.05.2020 17:19 # 2
Alicilik
I am always in favor of changing as a team. I changed the bulb a lot, but ballast frankly I did not try. I don't think it will be a problem as long as its features are the same.
If you use philps instead of Mtec, it will be different but I don't think it will be different if you use its equivalents. Reviews
08.05.2020 17:19 # 3
Enis KORKMAZ
This is the product, what is the equivalent of this now?
08.05.2020 17:19 # 4
I don't think there will be a change, I changed it two weeks ago.
08.05.2020 17:19 # 5
Alicilik
I saw it on ebay. It seemed to me like Chinese work. Others look better by looking. The feet of the bulbs are metal.
I suggest you try it from another vehicle. All of the 12v 35w ballasts but their efficiency changes according to their quality. I mean, from the equivalent, the same ballast can use different brands, so I suggest you look at different brands.
08.05.2020 17:19 # 6
Enis KORKMAZ
Trying to try another ballast, trying to try it is okay in the bulb, that's for sure. "http://www.hepsiburada.com/liste/modacar-h7-xenon-kit-yedek-beyin-balast-01f011/productdetails.aspx?productıd=otm01f011&categoryıd=271585&sku=otm01f011&navq = fh_sort_by% 3d-_match_rat% of 252C-item_sale_count_pl% 26fh_sec o ndid 3dotm01f011% 26fh_lister_pos% 3D2%% 26fh_locat of o n% 3d 252F%% 252fcatalog01 is 252ftr_t% 252F%% 2524s% 253dballast% 26fh_eds% 3d% 25c3% 259F % 26fh_refview% 3dsearch "target =" _ blank "rel =" nofollow "> http://www.hepsiburada.com/liste/modacar-h7-xenon-kit-yedek-beyin-balast-01f011/productDetails.aspx?productId= otm01f011 & amp; categoryID = 271585 & amp; SKU = OTM01F011 & amp; navq = fh_sort_by% 3d-_match_rat% by 252C-item_sale_count_pl% 26fh_secondid% 3dotm01f011% 26fh_lister_pos% 3D2% 26fh_locatio% of 3d 252F%% 252fcatalog01 is 252ftr_t%% 252F% 2524s% 253dballast% 26fh_eds% 3d% 25c3% 259f% 26fh_refview% 3dsearch
Enis KORKMAZ 2013-01-24 12:46:10
08.05.2020 17:19 # 7
Alicilik
[QUOTE = Enis KORKMAZ] We are trying to try another ballast, trying to try it. No problem in the bulb. I'm sure that
I'm thinking of getting it all from here. I was afraid that it would be incompatible with my eyes.
< div> http://www.hepsiburada.com/liste/modacar-h7-xenon-kit-yedek-beyin-balast-01f011/ productdetails.aspx? ProductID = otm01f011 & amp; categoryID = 271585 & amp; SKU = oTM01F011 & amp; navq = fh_sort_by% 3d-_match_rat% by 252C-item_sale_count_pl 26fh_secondid%% 3dotm01f011 26fh_lister_pos% 3D2% 26fh_locatio% 3d% 252F%% 252fcatalog01 is 252ftr_t% 252F%% 2524s% 253d ballast% 26fh_eds% 3d% 25c3% 259f% 26fh_refview% 3dsearch
This bold type is only different in size from yours. Biarz also seemed expensive to me for a single ballast. Reviews
08.05.2020 17:19 # 8
Enis KORKMAZ
The cheapest one is nowhere else, the bidet mine is not the same slim inputs but the size of the ballast does not matter.
08.05.2020 17:19 # 9
Barut
Last year, my left ballast failed and I installed a new one, there was no color difference.
08.05.2020 17:19 # 10
xdesign_206
Two weeks ago, my ballast was broken, I bought it from a random accessory, I did not notice anything in color.
08.05.2020 17:19 # 11
Enis KORKMAZ
Ok I am getting it all here. I also noticed that & nbsp; Alper AKSU and & nbsp; 206xs & nbsp; the left side is faulty in me, the left ballast is faulty was yours right or left? :)
08.05.2020 17:19 # 12
xdesign_206
my right ballast had failed "Smile"
08.05.2020 17:19 # 13
Enis KORKMAZ
Well then thank you very much to everyone. I will share the result here, is there any difference?
08.05.2020 17:19 # 14
fexzi
If there is no lens, use halogen, guys.
08.05.2020 17:19 # 15
Enis KORKMAZ
I put on the product I mentioned, but there are differences, guys. Normally it is close to dark blue purple 10000k but when I put on this ballast, it was a green-like color, one is different and one is different. In other words, ballast change caused color change.
08.05.2020 17:19 # 16
Enis KORKMAZ
Those with advice now?
08.05.2020 17:19 # 17
Enis KORKMAZ
Another problem to bring the new one from the USA :(
