Does Piranha adapt to my auto tape tool?
08.05.2020 18:58 # 1
ayna
http://m.kliksa.com/urun/piranha-charger-a-type-radyolu-usb-sd-mmc-giri-li-klas-r-se-me-zelli-i/900181028
Friends, I think to buy this product, but I do not know if it is suitable for my vehicle. I would be glad if you could help. My vehicle is 2011 model 206+.
08.05.2020 18:58 # 2
muro_60
when it comes to fitness, your joystick will be canceled, you will work, it will not be a problem, but I recommend you to buy a better quality tape.
08.05.2020 18:58 # 3
ayna
Since I do not understand this work, I thought if it was not working, when I put it on. I use the tape of the vehicle at most 2 times a month. When I go to the room, when I go 300km. Would it be too bad to sound from his normal tape? Though the original tape cannot be said to be of good quality.
08.05.2020 18:58 # 4
Adem Kurtuldu
If you say that it is enough if you do not use it very much, it is a suitable device, only the control of the vehicle will be canceled and it will not matter because you do not use it.
08.05.2020 18:58 # 5
ayna
I thought so exactly. I broke 2 fm transmitters I listened to the cizirdaya cizirdaya at least this is good sound quality. So if I remove the radio myself, can I install a new one myself? Is it a simple thing? Is there anything I should pay attention to, guys?
08.05.2020 18:58 # 6
samet206
Steering wheel control is canceled, but a better product will do your job, this is a completely lower quality product that fits and fits.
08.05.2020 18:58 # 7
ayna
For example, which product would you recommend? The control is not very important.
08.05.2020 18:58 # 8
ayna
Let's say I bought this product. So is there anything I should be aware of?
08.05.2020 18:58 # 9
Adem Kurtuldu
If it is no go in, connect it directly to the electrician
08.05.2020 18:58 # 10
ayna
Well I want to ask one more thing. Is this an easy thing to do aux input to my tape?
08.05.2020 18:58 # 11
samet206
It may be Sony DSX-A40UI. It can be Kenwood KMM-157. It may be James 7100. These are nice medium-level tapes. If you say it all, I recommend you to choose Pioner MVH-150 UB. Navitech TDC-4080 can be a bit more affordable for them. See this. Take a look at the models. Also, the antenna input may be different when it comes to the connection. Also, it is necessary to make a connection that is suitable for different new tapes. If you do not understand that it is not an operation with plug and play, do not enter it in my mind. There are apparatus such as aux input room Audio System Digital Music. You can enjoy usb-aux etc. in original tape but this product is as expensive as tape.
samet206 2015-01-02 00:16:43
08.05.2020 18:58 # 12
ayna
Thank you, I will investigate the models you call one. If I buy it, I'll have it connected to the electrician.
08.05.2020 18:58 # 13
zr`lmn
I had the tape of Piranha, and I was listening to the car's engine sound from the music, so I could listen to the USB sound in my previous car. They said, "I'll buy it. There are apparatus for preventing this sound." I do not know the brands and features, but a lot of Pioneer etc running sd card and usb. I have a brand-name tape
Edit: This was the tape I bought :) zr`lmn 2015-01-02 01:28:28
08.05.2020 18:58 # 14
Alicilik
I recommend zero or second hand mvh 140 1400 150 1500 1600 series pioneers cheap quality and useful.
08.05.2020 18:58 # 15
ayna
[QUOTE = zr`lmn] I bought Piranha's tape, I was listening to the sound of the car from the music so I used to play usb in my previous car. They said, "I'll buy it. There are apparatus for preventing this sound." I do not know the brands and features, but a lot of Pioneer etc running sd card and usb. I have a brand-name tape
Edit: That was the tape I got:) [/ QUOTE]
My friend, I gave up after this comment, thanks .. :)
08.05.2020 18:58 # 16
ayna
As you say friends, would you recommend me tape with a quality and under 100TL? I'm looking at the Pioneers now but they are machete. There are other brands but I can not understand if it is high quality
08.05.2020 18:58 # 17
muro_60
http://www.hepsiburada.com/liste/navitech-tdc-4080-arac-radyo-sd-usb-oynatici/productdetails.aspx?productıd=otdeltdc4080&categoryıd=26080
http://www.hepsiburada.com/liste/sony-dsx-a40ui-usb-ve-aux-girisli-kumandali-dijital-medya-alicisi/productdetails.aspx?productıd=otsonydsxa40ui&categoryıd=26080
you can get them
08.05.2020 18:58 # 18
ayna
Is Mavitech good quality?
I also found an Audio System changer 100 TL. How about it?
08.05.2020 18:58 # 19
ayna
Reviews for Mavitech are always positive. Frankly, that tape lay on my head ..
08.05.2020 18:58 # 20
ayna
Is it easy to do this, guys.http: //youtu.be/ZBZnsIFD2-I
Page : / 2
