DOES OXYGEN SENSOR DO NOT WORK AT LPG ??
08.05.2020 19:16 # 1
10URAKAR
Hello Friends,
Due to the problem of idling in my vehicle, I am finally stuck with the oxygen sensor.
But I asked a master to change it and gave me the answer ...
In LPG vehicles, the oxygen sensor is broken again, there is no need.
What do you think this means, the oxygen sensor only works on gasoline ..?
08.05.2020 19:16 # 2
vpro
When I broke down in my vehicle, the vehicle was making idle imbalance in both gasoline and gas. I changed it.
08.05.2020 19:16 # 3
10URAKAR
I had a previously lit fault light, but then I think the complete circuit was broken.
08.05.2020 19:16 # 4
vpro
Symptoms of this are my water teacher, even when the vehicle is at a low speed, it makes idle imbalance and even stays frequently but there is no problem at high speeds.
Bidet, I changed it for a long time, 5 months, no problem.
Note my sensor supply industry: D vPro 2015-05-14 11:02:35
08.05.2020 19:16 # 5
10URAKAR
Yes exactly, it does ... low speed is problematic but high speed is not problem ...
So let me change the sensor ...
08.05.2020 19:16 # 6
Cyrus35
The speed imbalance is also from the crank speed sensor. When the vehicle hits an advance, it turns out when the head is yio gas, it comes out gradually, rises, etc. If you are able to clean the oxygen sensor with lining spray, clean the throttle in the outside by holding the throat inside and wiping.
start by making the stages at the cheapest cost
