does not work in cold weather
08.05.2020 16:37 # 1
akay70
hello peugeot 206 in-line system has lpg it does not work in cold weather, it works normally when the air gets a little warm, i took it to the master, he connected it to the computer, no problem & nbsp; it does not appear, then & nbsp; he said from the starter, he made the starter again, he did not work again, he said that he changed it, the car worked without problems after a week, he made the same fault again I would be glad if you could help what could be the reason this winter & nbsp; this & nbsp; because of the car, I suffered a lot of disgrace.
08.05.2020 16:37 # 2
Do you mean that it doesn't work, but does it get mars or not? Are you a little more hungry?
08.05.2020 16:37 # 3
okankrgz
Does your vehicle work
08.05.2020 16:37 # 4
akay70
the starter presses normally does not work on the vehicle
08.05.2020 16:37 # 5
aspirinxlarge
I think it has nothing to do with lpg, & nbsp; I think that there is a problem in firing since it is working with gasoline until it is already warmed up. & Nbsp; The starter I do not understand is that there is no reaction in the vehicle, that is, the engine does not ignite, it means spark plug etc. I know what I think is a problem in that kind of thing. & nbsp; Otherwise it would be a problem not to switch to lpg. & Nbsp; Write a little more detail, and someone who knows the problem will surely appear. & nbsp; The information you provided is incomplete. & Nbsp;
08.05.2020 16:37 # 6
akay70
When the vehicle is pressed for the first time, it feels like it will work. It does not react at the next presses. The starter presses very well.
08.05.2020 16:37 # 7
ByHack
I seem to be likely to have spark plugs ....
08.05.2020 16:37 # 8
dukenukem82
In the spark plugs, the exhausted battery does not get reinforcement, it ends in two minutes in cold weather.
08.05.2020 16:37 # 9
akay70
Thanks for your interest, when the first exhaust was not working, the master exhaust was blocked, the exhauster only changed the rear exhaust, the second medium was blocked in the second run, but I changed it right now, the car has returned to normal, but the masters changed a few pieces until we found this fault & nbsp; 350 tl went.
08.05.2020 16:37 # 10
comrade1917
Unfortunately, I have the same problem with me. They changed the gas pump, they did not change it. I would like to try your solution. Good evening.
