Does not start, does not work by knocking
08.05.2020 20:44 # 1
radman206
Hello friends. I will tell you a problem. I want preliminary information.
My 206 1.4 hdi car did not work. We did not even click on the starter. 3-5 minutes Then he took the starter at once and worked. I pulled uphill and started and stopped. Worked 2-3 times then cut again. I tried to start it by hitting it even when the starter did not say `click` He did not take it by shooting. He worked again after 3-5 minutes. Now he continues to work at once. I'll take it to the mechanic. Does anyone have any ideas or ideas?
Thanks, radman206 2018-01-22 21:17:34
08.05.2020 20:44 # 2
ALLEX
[QUOTE = radman206] Hello guys. I will tell you a problem. I want preliminary information.
Thanks, [/ QUOTE]
Such problems can occur with a drill motor, ignition key or slot, battery not holding amps, or a short circuit in one place.
As if there is no solution other than a competent auto electrician.
It is sure that there is no fuel problem.
Get well soon. If the problem is resolved and you share it under this title again, you shed light on other friends.
Respects.
08.05.2020 20:44 # 3
ismailkaya
When the starters are not pressed, do the indicators confirm and function? does it work? If the saddle is working, look at it if the vehicle has a speed sensor.
08.05.2020 20:44 # 4
radman206
Indicators, tape and light Everything is working properly. The battery is new and supplied. The starter motor seems solid because it takes it all at once when it is pressed.
08.05.2020 20:44 # 5
Have the crank speed sensor checked. sonerkyl 2018-01-23 08:54:11
08.05.2020 20:44 # 6
ysf_syfttn
It consists of 90 percent crank sensor, the same was in me;)
08.05.2020 20:44 # 7
radman206
The malfunction was in the starter motor. The event has grown a little. Oil and water leakage started in the engine, which corresponded to the starter motor. Water and oil have seeped into the starter motor. Starter motor was changed. Problem solved.
In repair for oil and water leaks.
08.05.2020 20:44 # 8
OguzhanKucuk61
I guess it has changed in coal, I guess. Thanks for your feedback
