does not eat gas on departures and cuts off gas on the way |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:13 | # 1 |
hello friends peugeo 106 quicksilver I have a car, the car does not eat gas on take-off, it seems like it will stop whirling when I press the gas. On the way to the road, the gas cuts off, the charge lamp flashes, the vehicle does not accelerate ... it turns back to normal when it pulls my foot out of the light gas.
| 08.05.2020 16:13 | # 2 |
muzaffer |
I say, look at the spark plugs on the ignition cables, the tube dimmer may also have a problem in the brain of the vehicle.
| 08.05.2020 16:13 | # 3 |
I had the same problem in my polo car, the problem was elsewhere in the polo dispenser, if your vehicle has a dispatch reel, look at it
| 08.05.2020 16:13 | # 4 |
taksicicocuk |
When I come from the bathhouse, I have an electric master in my brother: D 1- charge dynamo connector, makes from 2-coil says to the scholar ...
| 08.05.2020 16:13 | # 5 |
the cylinder gasket may have cut. Because water enters the combustion chamber, it whirls, that is because it cannot burn the water.
| 08.05.2020 16:13 | # 6 |
I asked one more master about the spark plug cables or the charging dynamo.
| 08.05.2020 16:13 | # 7 |
Long Beach |
If the charge lamp is on, the charge dynamo coals are exhausted.
| 08.05.2020 16:13 | # 8 |
I have a look at the car's dynamism, but there is no gas shortage in gasoline and LPG. sometimes the vehicle is stopping and the charging lamp is already remembered while the steering wheel is getting harder. I'm waiting for your help urgently.
| 08.05.2020 16:13 | # 9 |
ares2626 |
I have the same problem, I brought the service to the service, he says he shouldn't clean the throttle, if the room did not pass the valves would have changed. If I think they are cleaning the throttle for 30 TL, the problem is 2 celenoids in the valves. What is it from 160 to 320 TL oil and 350 fln ...
| 08.05.2020 16:13 | # 10 |
istanbullu_3886 |
replace filter may be clogged
| 08.05.2020 16:13 | # 11 |
[QUOTE = ares2626] I have the same problem, I got it to the service, he says he shouldn't clean the throttle, if the room did not pass the valves would have changed. If I think they are cleaning the throttle for 30 TL, what is the problem in the valves? Is it 2 sellenoids? What is the problem between 160 and 320 TL oil and 350 fln? automatic & nbsp; solenoid parts in transmission & nbsp; I wondered how they formed a relationship between the throttle and this solenoid ???? |
| 08.05.2020 16:13 | # 12 |
The filters have also changed, and I have carefully cleaned myself in the throttle. If I press the gas of the car to the end, it stops immediately.
| 08.05.2020 16:13 | # 13 |
hello friends right now the same problem is with me when I go uphill and turn the corners, the car cuts off the gas and when I go, I do not understand that the oil lamp is flashing very fast in the smallest bumps. I would be glad if you write your thoughts right now
| 08.05.2020 16:13 | # 14 |
The same problems in my car continue without any difference and the same problem in my friend's car is also in my car
| 08.05.2020 16:13 | # 15 |
my brother had the same problem in my 306. The gas cube under the hood has a reel, if I think there is a plug, blue & nbsp; green red and black & nbsp; one of those little cables might be broken. I changed that plug, it was fine.
| 08.05.2020 16:13 | # 16 |
[QUOTE = mehmetaydinpug] hello friends, the same problem is with me right now when I climb uphill and turn the corners the car cuts off the gas and the smallest bumps on the way & nbsp; oil lamp flashes very quickly, I don't understand where the problem is in the car's oil. he says something else i can't drive my car i would be glad if you write your thoughts right now [/ QUOTE] .... i just wrote it to the brother. mine gas bar & nbsp; They said pumice in the warehouse & nbsp; I found it coincidentally while myself was playing it; A small plug room clears in the bumps connected directly to the brain, and it seems like it will make air almost in the slopes.
| 08.05.2020 16:13 | # 17 |
ares2626 |
You are right, my brother, I let the gas butterfly clean up, I think the problem has changed the solenoid pressure valve to eliminate this error.
| 08.05.2020 16:13 | # 18 |
The car gets furious when I load the ramp up to the gas, and sometimes the charging lamp also lights up.
| 08.05.2020 16:13 | # 19 |
[QUOTE = ares2626] I was right, my brother, I had a blast of a master, I thought the gas butterfly was clean, I think the problem was solenoid, the pressure valve has changed, to eliminate this error. [/ QUOTE] is the car auto? |
| 08.05.2020 16:13 | # 20 |
106 1.4 75bg quicksilver gasoline + lpg I have cleaned the sensors including throttle today with lining spray, but the result is still the moment.
