Does Not Eat Gas at Light Pressure |
| 08.05.2020 19:47 | # 1 |
My vehicle is going to tell 307 in 2005, 307 with tubes, in gas and gas. I had CC installed on my vehicle recently, whatever the person wearing it was stopping at idle. Anyway, we adapted the butterfly to the vehicle we researched. First vibrations started at idle. 2. When it is idle, when the gas is pressed very lightly, the vehicle does not detect it and when it presses a little more, it goes up to almost 2 thousand revolutions. Normally, I can say that it does not see 1.1 1.2 giants by pressing lightly, When 3rd vehicle is on air conditioner or fan etc., the vehicle stops when it is loaded and released on idle. Can I get rid of the butterfly by cleaning it? Or is it doing something else? I wanted to get your ideas. Also, is there a glazier in Ankara where I can make rain sensor gel? sometimes it twists because the bubbles are formed. The rain sensor does not work when the headlight is activated. Working with headlight off vsvs :) Thanks for the answers ..
| 08.05.2020 19:47 | # 2 |
sonerkyl |
Hmm. cc wearing friend is my friend in our forum. I think this happened after the cc was installed. Priority to make gas adjustment again, some settings may have changed after the CC was installed. When the LPG setting is compared to the old settings, there may be such problems. As you said priority, clean the throttle, adapt again and adjust the throttle. |
| 08.05.2020 19:47 | # 3 |
Yes, I am thinking of making gas adjustments from the forum, but it has the same problem with the vehicle gasoline.
