does not collect steering ..
08.05.2020 14:11 # 1
kamilgulcan
good evening everyone...
2006 307 sw car ... 2 days ago I replaced my tires with pirelli p6000. The problem, which I felt very little before and that I did not emphasize too much because of the rot setting, has increased significantly. There was also a little left pull on straight travel but it also increased. I wonder if the rod will be fixed with balance or is there a problem in the steering system? I don't think it's new tires because the same problem with the old tires was a bit ...
Could it be for the same reason that there is excessive influence from the side wind and the steering shaking problem that I mentioned earlier and still cannot be solved?
08.05.2020 14:11 # 2
BuRCaK
Hello Brother.
I had 307 1.4 HDI in 2008. the steering was both collecting and turning as if it were stuck. the steering wheel has changed ... unfortunately that was the problem with me. but then it became like cotton steering wheel. My friends who use it still say the steering had been very good. if this is the problem, it is very expensive in service. but in industry I think you will find it from peugeot particle or OTO EFE. Put it on a master you trust. I think OTO EFE helps in this matter ...
Get well soon.
BAT007 2010-03-08 23:26:40
08.05.2020 14:11 # 3
When I was on the road 3 months ago in my 307, the steering did not move, it was improved when I turned it strong, it happened 2 or 3 times, but it has not been stuck for 3 months.
08.05.2020 14:11 # 4
SUPERMAN
my vehicle was also pulling right, picking hard etc. I made ten complete sets and rot adjustment was done, and when the tires were changed and balanced, they were all very well done, but they did not make my balances properly in your vehicle.
08.05.2020 14:11 # 5
hasimayaz
One of the most common mistakes in rot balancing is to take the vehicle to the rotter without the parts and preparations that need to be changed.
Mechanical problem in the vehicle, tower curvature, rim runout, tire defect, direct adjustment without any control.
08.05.2020 14:11 # 6
kamilgulcan
the tires were meticulously balanced for 2 days, the wheels were also checked .. the steering wheel does not get stuck or hardened, the maneuvers are very soft at high speeds, the hardening is normal. ) this situation decreases or increases according to the slope and quality of the road. it feels like there is a slight gap to the left, but there is no sound, the steering spontaneous right-left responses are also normal. I don't think so, but I hope it is not the steering gear, but the source of the problem. It feels like rot setting because it has a little left to me. (I can't spare time for rot setting, this week is 1-2 weeks busy)
08.05.2020 14:11 # 7
peugeotefe
replace the ball joints first, you may need to replace the steering gear if your problem persists. steering wheel wear or worm shaft problem
08.05.2020 14:11 # 8
I think only the steering knuckle may also be defective. The same problem was with your friend's 2008 model partner.
