Does my 3008 burn VERY? Please write an answer.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 20:19 # 1
mehmet simsek
My car Peugeot 3008 diesel automatic 2012 model at 43000 km.
I'm buying 100 pounds of diesel, it takes 300 km.
I buy 100 liras diesel again, again 300 km later, the red light is on.
so it goes 100km to 300km
it seemed like a lot to me.
On the screen, the fuel value is 7.2, and my speed is 26 km.
I get the diesel from bp.
and I usually use inner city.
Thank you in advance for your comments.
In particular, I expect an answer from the 3008 owners.
08.05.2020 20:19 # 2
ggitaristt
It burns a lot, brother ..
08.05.2020 20:19 # 3
Merictasasiz
I use the same tool. The car really burns little. It seems like the diesel is very expensive for you. These values are quite normal.
08.05.2020 20:19 # 4
uzunca961
The same engine is also available in 308. For this reason, I guess that maybe it will burn a figure close to 308 even if it is not the same. I see an average of 6.2 average speed 28 and an estimated 6.5 maybe 6.7, if we say that the vehicle burns about half a liter. The reason for this is generally due to the sub-industry filters used in maintenance, and if the brake pad is changed, it is also caused by unnecessary braking. Of course, there may be other reasons. You should have it checked. Of course, you'd better have someone look familiar because there might be unnecessary parts replacement to pay
08.05.2020 20:19 # 5
sanctuary35
Although the vehicles like 3008 c4 picasso are the same engine, the fuel is too heavy because the case is heavy, but your average is 1-2lt too much.
08.05.2020 20:19 # 6
ggitaristt
My car is 3008 5008 heavier than all but it does not exceed 5.5 liters in the city .. There is a problem in your car ..
08.05.2020 20:19 # 7
maximusti
2012 1.6 e-Hdi 3008 s factory consumption 5.8 / 100
According to the factory, it should burn 17.4 liters of diesel at 300 km. tl equivalent of 78.3tl.
using a short distance, getting up and running a lot, driving up a lot, and using aggressively will increase this amount. There is apparently an increase for such a reason.
08.05.2020 20:19 # 8
mehmet simsek
Well, my mood is down.
08.05.2020 20:19 # 9
Oktkor
Normal. Speed 26 km. There is a difference inside the city. 33 cf. Don't bother.
08.05.2020 20:19 # 10
maximusti
[QUOTE = Oktk] Usual. Speed 26 km. There is a difference inside the city. 33 cf. Don't bother. [/ QUOTE]
normal speed, short distance km 50 krş. Feel great :)
08.05.2020 20:19 # 11
Oktkor
[QUOTE = maximusti] [QUOTE = Oktkor] Normal. Speed 26 km. There is a difference inside the city. 33 cf. Don't bother. [/ QUOTE]
Oleeey :)
Last year when diesel was 3.60, I went to a barter campaign for toyota corolla. Of course, I tried to praise that he was burning 33-35 cents for that corolla, which he called magnificent. Now diesel 4.6.
08.05.2020 20:19 # 12
OguzhanKucuk61
I think there is no need to say there is a problem with the vehicle directly ..
If you ask me, there is no problem in the proportion of km and fuel spent.
Comparing it with 308 and saying that a half liter difference is caused by a problem may be wrong, it may have the same engine. The 0.5 liter fuel difference may not be related to filter replacement or a problem. Due to the high and wide structure of the car, this may be the difference. Even the way you press the gas is very important. A value like 30 cents is normal for an automatic SUV, even if it is diesel.
If it is desired to decrease below 30 cents within these pump prices, B segment diesel can be preferred.
08.05.2020 20:19 # 13
GokhaN
It burns well. No problem.
08.05.2020 20:19 # 14
OguzhanKucuk61
Hybrid vehicles are the most ideal for those cities that do not have much speed and have high traffic.
If you do not expect performance on highway and intercity roads, it can be considered.
08.05.2020 20:19 # 15
ggitaristt
Either do not get it wrong, the friend warms and warms and opens the same subject .. I know the car burns perfectly normal .. But we couldn't explain it for 1 year .. So I say: Yours burns very well .. Refresh the complete engine ..
08.05.2020 20:19 # 16
Oktkor
My teacher then takes 1.4 or 1.6 polo and burns less.
I guess we ignore some parts when buying a car.
If you want to be less economical, b segment light vehicle will satisfy you.
If you think that no segment is big enough for me, then you will not look for this segment economy.
If you say to me that my brother is both big and little, you will have to open the mouth of the pouch so that one or two vehicles will come out and the engine in your hand is very economical.
Consider factory data, it is considered normal to be slightly higher than it.
But my advice to you is to buy. If that car burns 12 cranes, it will seem too much. :)
08.05.2020 20:19 # 17
maximusti
[QUOTE = ggitaristt] Either do not get me wrong, the friend warms and warms and opens the same subject .. I know the car burns quite well .. But we haven't explained it for 1 year .. So I say: Yours burns a lot .. Refresh complete engine ..
08.05.2020 20:20 # 18
OguzhanKucuk61
Thank you
08.05.2020 20:20 # 19
mehmet simsek
If there is anything you don't like, you won't comment.
08.05.2020 20:20 # 20
ggitaristt
[QUOTE = mehmet şimşek] If there is anything you don't like about scum, you won't comment.
Yours are burning too much ..
Page : / 2
