Does my 2017 model 3008 burn a lot?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 20:57 # 1
adana01
good day guys I have two problems, I would appreciate if you help.
one )
2017 allure elagance 3008 1.6 string, I joined you. My vehicle is now at 10,000 km. I have a problem with fuel. My vehicle burns an average of 8 liters, I don't see it below. I would be glad if other 3008 owners also share their fuel consumption values in the comments. I went to the related service. the service said there was no problem and they tested it and got 4.7. Of course, I do not see this value even outside the city.
2nd )
The gearshift gaps of the vehicle seemed a bit too much to me. my previous vehicle was going with dsg 70 with 7th gear. When going with 3008 and 70, there is 5 gears. it seemed like this was making the car too heavy. Could it be something like shortening the gear ranges, or will we ride this way?
08.05.2020 20:57 # 2
HasGur
The manual with a 1.6 HDI engine that I left for my 72 year old father goes to the mosque 2-3 times a day, comes to the market 1-2 times a week to the market ... So I always use a short distance and a cold engine ... But in 15 months, all of them have traveled 6 thousand km.
In such a use, the trip computer shows about 7.4 - 8.2 liters per 100 km, but the actual consumption is between 8.5 and 9.4 liters every time I fill the tank.
I go a long way with the same vehicle. I always fill the tank from the same pump and fill it again. The trip computer displays between 3.6 and 4.1 actual consumption is between 3.8 and 4.4.
In other words, the way of use affects fuel consumption very much. If you are using in short distance / traffic, it can be called normal. If you can make a road up to 100 km out of the city, you can evaluate the fuel consumption correctly.
08.05.2020 20:57 # 3
RooT_TooR
[QUOTE = adana01] friends have a nice day. I have two problems, I would appreciate if you help.
one )
2nd )
I have 6 eat 2015, it shows 7.5 in the city, I see 11 liters instantly, even if I use it fast, I use it according to its way. Since Eat 6 is fully automatic, my 7.5-8.5 normal old vehicle diesel was fully automatic in the city, it weighed around 1300 kg, and my 10-liter city average was not. If I don't remember 3008 wrong, 1540 (2015) is your 2017, I think your vehicle is around 200 kg lighter than 1300 kg. The problem is that you are not driving very economically, but very carefully, on the long road. Once I exaggerated, I traveled about 200 km at a speed of 60-90 km, completed it at the pump and burned 35 TL. In short, if you are looking for a little bit of burning that can not be said, you will turn to single clutch vehicles and now it burns as much as fully automatic in double clutches. None of the automated vehicles are fuel misers, especially in the city
root_to is 2018-07-07 19:26:06
08.05.2020 20:57 # 4
okan0752
How can I ask a question here?
08.05.2020 20:57 # 5
GokhaN
one )
2nd )
I'm using 2010 1.6 hdi too
- Around 7.5-8 lt with air conditioner etc. on summer days is quite normal.
- dsg system standby 5 to 70 normal because its standard is certain
08.05.2020 20:57 # 6
GokhaN
[QUOTE = okan0752] I can't find how to ask a question here is gone [/ QUOTE]
If you want to write a message for which topic, click on that section on the homepage, when you enter the topic page, you can open the new topic by pressing the new topic button at the top left or bottom left.
08.05.2020 20:57 # 7
maximusti
factory data intercity 4.7 intercity 3.9
these tests are measured at a fixed area of 100 km in a flat area of 100 km, so it is normal to add an additional +1 +1.5 lt in real life.
short distance in the city, a slope area, aggressive use, air conditioning etc. In cases it goes on adding it.
my car is going up to 14 15 liters instantly but the average of the last 1800 km is 7.7 lt.
08.05.2020 20:57 # 8
ibrahim01
thank you for your comments
08.05.2020 20:57 # 9
Tarkan
2012 3008 there is an average of the last 1500 kilometers, around 7.3 continuous medium traffic short distances within Istanbul
