Does LPG go to automatic?
08.05.2020 21:04 # 1
akyuz.cagri
I am using the 2001 model 1.4 xr. Do you think it is worth shifting the automatic gear, tube, I would like your ideas and information, what will be the fuel consumption if we install the in-line system ...
08.05.2020 21:04 # 2
Karacocuk24
[QUOTE = akyuz.cagri] I am using the 2001 model 1.4 xr. Is it worth it to install automatic gear, tube, I would like your ideas and information if I install the in-line system. It has been 25 thousand km. It has not been a problem until now. When it comes to fuel, you will have a certain savings of 40%.
08.05.2020 21:04 # 3
GokhaN
[QUOTE = Karacocuk24] [QUOTE = akyuz.cagri] I am using the 2001 model 1.4 xr. Do you think that it is worth installing an automatic gear, tube, if we install a sequential system, what will be the fuel consumption, I need your ideas and information ... [/ QUOTE] same vehicle I have atiker, I have had it for 2 years, 25 thousand km has not been a problem until now. When it comes to fuel, you will have 40% definite savings, but if your car needs to work stably in petrol, it is appreciated if you don't use 2-3 km short distance [/ QUOTE]
Thumbs Up
08.05.2020 21:04 # 4
x571
[QUOTE = akyuz.cagri] I am using the 2001 model 1.4 xr. Do you think the automatic gear is worth installing a tube?
1.6 burns 40 cents in the city. distance 5 km. There are 3 red lights and 2 slopes. I go on the first 1 km gasoline. Is it worth it? At 30 thousand km, 10 thousand TL of profit is made from the halal difference of LPG.
