Does LPG fit smoothly
08.05.2020 19:39 # 1
Selcuk23
Hi friends car 2011 peugeot 308 1.6 vti petrol automatic
I use my car in the city and it is about 11-12 liters of gasoline. About 50 kurus per month, I do 1000 km per month. What would you recommend? .Soundly
08.05.2020 19:39 # 2
hello selcuk bey lpg, they recommend the brand of prins to your vehicles.
08.05.2020 19:39 # 3
mimit
There may be another problem in the vehicle, the consumption rate is too much, I do not consume it with a 2.0 fully automatic vehicle.
lpg is attached but as it says, it is much better quality as prins brand, but it is useful to have it applied to a big dealer, vti user who also has problems in lpg due to some mounting errors is also a lot.
08.05.2020 19:39 # 4
Selcuk23
Yes, we use it at short distances. In the city, the car will stop, thank you very much.
08.05.2020 19:39 # 5
mimit
Since the engine does not heat up, it is normal that the vehicle burns very much, and the winter conditions are burning an average of 1 -1.5 liters in Ankara. In order for the lpg to work well, the engine temperature must reach a certain level, so it may not be very economical in the lpg during short distance driving. it may even take a long time to cover your expense.
You can show it to a service for control purposes. If the ignition elements are checked, take a look at the injectors.
08.05.2020 19:39 # 6
Selcuk23
Thank you. Actually, your determination is right, until the engine warms up, I arrive where I will go. I go to school. 4 km arrival. 4 km.
08.05.2020 19:39 # 7
KILIC
Sir, there is no problem in the vehicle. Your vehicle is automatic, factory data is already in the city 10lt. Normal is the data. If you install LPG in your vehicle, it will burn around 12-14 lt in LPG. that is around 30-32 krş. I agree with friends prins is good If you find a decent master, it is inedible. But if you travel 10 km daily, I think there is no need. If you are already going 4 km, you will go to school until the engine warms up, you will go to the gas station, stop the car in the night, you will arrive at your destination :)))
08.05.2020 19:39 # 8
dagdelen34
If you are going to use the car in the long term, you will definitely pay for it in a short time and you will have no problems if you install it in beautifully recommended places.
08.05.2020 19:39 # 9
popeyes
I have used LPG LPG and did not lose as efficiency. the fuel also fell to 0.19 profits. On the long road, I saw 0,16 0,17 crumbs, and I got on a year without trouble. I had a OBD 2 system wreck for 1100 TL. Also, when I was going with LPG, I had another kit installed so that it would not fall on gasoline.
