Does Auto Chance Stop?
08.05.2020 19:26 # 1
Derya
Hi friends,
My car is 2000 model Ototmatic 206 1.6.
It takes 2 months to be maintained. On this day it stopped at the lights. At that moment, the cycle increased as if I was loaded into the gas .. and stopped ..
This is not the case with the automatic vehicle that I know. It wasn't in the park.
I switched off the ignition completely and started it again. Normally it was difficult to get the gas and I could get up. There was no problem in me.
Does anyone have any idea what could it be?
08.05.2020 19:26 # 2
The porblem in your derya lady car may be caused by the throttle-dirty fuel-gasoline filter-injectors-spark plug and coil. If you say the vehicle has given gas to itself, it is likely to be caused by idling sensor. Of course, if he is constantly doing it, I recommend you to check what I have said. Of course, we try to help according to what you say here.
08.05.2020 19:26 # 3
Derya
I changed the spark plugs when it was serviced. All the other options you mentioned were left behind.
Hopefully it can be solved with a simple intervention .. it does not cost :(
thanks for your reply ..
08.05.2020 19:26 # 4
There are a few options that I said, stop right now, or there is dirty fuel for that moment. I recommend shell nitro + once in a while.
08.05.2020 19:26 # 5
talip206
Normally, the automatic vehicle does not stop. If it is done once, it may be due to fuel. If it continues, it can do from the gas filter, the throat butterfly is dirty, for many reasons. such stopping events may not cause much trouble in normal transmission, but I recommend you to have the vehicle checked because it can cause bigger problems in automatic gears.
08.05.2020 19:26 # 6
Derya
Thanks talip206 ..
I will not feel comfortable. I'll have it checked as soon as possible ..
It was the first today. I don't know if I will do it again.
