Does anyone know the name of this piece?
08.05.2020 21:10 # 1
kaanbayuk
friends what is the name of the blue socket where the mouth of this pipe passes into the air filter, the mouth is wider than the yellow socket in the oil vent pipe. I searched for something on the internet, I could not find it, I need this piece urgently. I'm waiting for your help
i
kaanbayuk 2019-02-24 12:55:08
08.05.2020 21:10 # 2
RP393
The crankcase ventilation teacher takes air from there and goes back to the intake manifold from the oil vapor hose. There is a solid vacuum to say that I will put your hand while the vehicle is running.
08.05.2020 21:10 # 3
kaanbayuk
crankcase ventilation hose, thanks, I also have this hose idle when the vehicle is stolen when I close the pipe with my hand, the vehicle stops :) I am looking for that blue socket to plug this pipe into the air filter, I couldn't find it anywhere kaanbayuk 2019-02-24 16:30:22
08.05.2020 21:10 # 4
RP393
[QUOTE = kaanbayuk] I think it is not the oil steam hose, the oil steam hose with yellow socket, [/ QUOTE]
It sucks air from blue to the crankcase and blows yellow from the crankcase.
08.05.2020 21:10 # 5
kaanbayuk
Thank you very much, my vehicle had a sports filter, I found the original filter parts, I did not want to connect this pipe to the hole in the air filter.
08.05.2020 21:10 # 6
kaanbayuk
is this socket in your car blue kaanbayuk 2019-02-24 16:36:57
08.05.2020 21:10 # 7
RP393
[QUOTE = kaanbayuk] Is this soekt on your vehicle blue [/ QUOTE]
Yes, the same notor is in my car and it's blue. It should fit like the yellow one. I think the clamp would be more solid.
08.05.2020 21:10 # 8
kaanbayuk
My other pipe is with a yellow socket, as you said, but this is not a blue socket, the blue socket is inserted into the pipe, the hair is tightened with a clamp, and the blue socket is inserted into the air filter.
08.05.2020 21:10 # 9
Frt-Aydin
vehicle diesel
08.05.2020 21:10 # 10
kaan206
bnzin and lpg li
08.05.2020 21:10 # 11
Frt-Aydin
Mine is 206 gasoline but I don't have that part in my car
