Does anyone have a bagel LPG on 307 Sw vehicle?
08.05.2020 15:24 # 1
hantsome28
Hello friends, since I was on the eve of installing LPG on my model (2004 model 307 SW.Triptonik), I heard that there were people who donated bagels as a result of my researches. blusing
NOTE: 307 SW vehicles are not inside the normal 307s but are external stepper .....
The spare tire is attached from the bottom to the bottom. At this point, exterior mounted LPG tank can be used ...
the cecol 2011-05-11 10:22:53
08.05.2020 15:24 # 2
hantsome28
is not there
08.05.2020 15:24 # 3
MemoTech
The link below is a recent link friend made new.
Briefly, the casing is added to the place where the spare wheel is located and if the height is 20cm from the ground, there is no problem.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14420
08.05.2020 15:24 # 4
hantsome28
memotech tşk .... link was too ii ..
08.05.2020 15:24 # 5
I Installed The Fuel Tank As A Donut On My Previous Vehicle, I Have Not Seen Any Boredom,
Of course spare tire wasted ...
Since I Did Not Go Long, I Decided Such A Practice ...
08.05.2020 15:24 # 6
[QUOTE = ColonelDemircan] I Installed The Fuel Tank In My Previous Vehicle As A Donut, I Have Not Seen Any Trouble,
my colonel you are wrong you understood the event :))
Since this vehicle is sw, the spare wheel is from the outside. Asking to install the tank from the bottom side of the friend :)) Normal 307 is not a problem anyway. because it gets stuck inside ...
08.05.2020 15:24 # 7
our last son, our friend got it :)) you will understand if you read the subject ...
they hang the tank from the bottom to the top sheet and under it a protective sheet is attached. it is very solid and smooth. but this exterior warehouse event is not in every brand scarce. be sure that it does not want to deal with many people. project, etc. But I think you should go to the MMO room wherever you are in the case of the examination. get information ... sometimes they can make hair. There is no standardization spread all over Turkey. while some say no, they wear and use others here. happening on inspection :))
a situation entirely in Turkish :))
08.05.2020 15:24 # 8
burak_efe
I got it from zaholi 3 months it is no problem. Meanwhile, the simit warehouse is replaced instead of the spare wheel.
08.05.2020 15:24 # 9
hantsome28
do you have burak photos .. for an idea
08.05.2020 15:24 # 10
ismail ozdemir
My vehicle is not a sw, but I put it in the trunk of the tube simit spare wheel tomorrow, and it is considered a mild defect because there is no spare wheel connection in the muyan :)
08.05.2020 15:24 # 11
hantsome28
I talked to the samsun dealer of 2a engineering about the simit warehouse ... they told me that they received 90 TL from the extra simit that we were talking about. He said he did not recommend Beijing because it could not be provided. I remained unstable. LPG kit BRC-MY 11
08.05.2020 15:24 # 12
GANDALF
my car 307 SW automatic 2.5 years ago I got stuck in the request, at the same time I had a protection shield at the same time, just in case it was atiker lined and I think it was safer to have the tube under the car.
