Does anyone have 206+ xenon users
08.05.2020 15:22 # 1
emin1689
mrb is friendly. 206 plus I will get xenon on my car but I have a few questions
1- Is there any damage to the vehicle in xenon application? electronically or physically
2- 6000 or 8000 headlights?
3- Will there be xenon on fog light? Can they make 20,000 crazy blue
08.05.2020 15:22 # 2
toprakk
According to your head, brother. you have no problems. they are even optional, even at the factory. In the kw selection, I think it is clear that there are 8000 tactical x-zenon. 6000s are very weak we are turning yellow we are ineffective.
08.05.2020 15:22 # 3
emin1689
20 thousand is installed in the fog, no problem
08.05.2020 15:22 # 4
metin
yaw friend you are talking about 20.000. the original is 4350K, but do not sin. Especially if you don't have a lens, stay away.
08.05.2020 15:22 # 5
dinoco
8000k is the most ideal.
the dipped beam headlights are h7 .. the highs are h7 but you should only apply xenon to your SHORT LIGHTS.
Attach normal white osram bulbs to your main beam. do not wear xenon.
In short, apply only a set of h7 8000k and a set of h1 8000k xenons to your shorts and fog.
Of course, do not forget to make your parking bulbs side signal bulbs and white bulbs in your license plate lighting :)
08.05.2020 15:22 # 6
oguzhan29
No problem, if you are going to wear an 8000-inch fog headlights from the sister exenon for ornamentation, it will do a nice blue job.
08.05.2020 15:22 # 7
forewer_fb
high beams are not already attached, you need to change the headlight to be able to install bi-zenon in the zenon headlights they call, so the white bulb is the most beautiful. 8000 is very nice to its normal headlights. Also there are separate zones for the latest vehicles, which are electronic, there is a difference like 30 TL. Even the fog does not work, but a reality looks very good.
08.05.2020 15:22 # 8
emin1689
I put 20 thousand on the fog for the image. now the fog is 20KK. short 8000k. what is the average price. In a park, is there a big ampoule attached to the parks?
08.05.2020 15:22 # 9
forewer_fb
It does not matter the price of 20000 or 8000, the value determines the color of xenon, they give a price between 130-150tl for new model vehicles, you need 2 sets, it will cost around 250-300, if you want, there are white bulbs in the parks, the blue for the signals looks blue but it lights up yellow. would
08.05.2020 15:22 # 10
dinoco
[QUOTE = forewer_fb] does not get stuck in the high beams already, you need to change the headlight to be able to install the bi-zenon in the zenon headlights they call, so the white bulb is the most beautiful. 8000 is very nice to its normal headlights. Also there are separate zones for the latest vehicles, which are electronic, there is a difference like 30 TL. Even the fog does not work, but the truth looks very good. The choice is yours [/ QUOTE]
xenon stuck on high beams. It doesn't have to be a xenon. Plumbers don't want to plug it in because it's just not useful.
08.05.2020 15:22 # 11
forewer_fb
Why do not they want to plug in? When xenon is first turned on, it comes late and gradually max. reaches the power, then goes off and lights up directly. How will this be when we want to make a selector? Are we always traveling long? What is the sin of the opposite driver?
08.05.2020 15:22 # 12
dinoco
That's why they don't wear it. We got stubborn, then we took out the kitty :))
08.05.2020 15:22 # 13
eren8er
this is something i never thought of getting my own vehicle installed. I get an invitation to the accident .. and also tinnitus :)
08.05.2020 15:22 # 14
dinoco
If the focus settings are not done well, you are right. you are very right. We are now a nation that even wears xenon in a horse carriage :))
08.05.2020 15:22 # 15
emin1689
When you plug in xenon, headlight low height adjustment is disabled. the steering wheel has more or less left adjustments? Is it canceled when xenon is installed?
08.05.2020 15:22 # 16
Mesut
My brother is peeking from me hicc gırgır look at the xenon temperature.
08.05.2020 15:22 # 17
forewer_fb
[QUOTE = emin1689] also, when installing xenon, headlight low height adjustment is disabled. the steering wheel has more or less left adjustments? Would it be canceled when xenon was installed? [/ QUOTE]
There is no problem after changing the headlight, not with the headlight related lamps, some angel headlights are compatible with the headlight motor, which makes the headlight height adjustment you mentioned.
08.05.2020 15:22 # 18
xdesign
[QUOTE = forewer_fb] [QUOTE = emin1689] also, when installing xenon, headlight low height adjustment is disabled. the steering wheel has more or less left adjustments? Would it be canceled when xenon was installed? [/ QUOTE]
There is no problem after changing the headlight, not with the headlight related lamps, some angel headlights are compatible with the headlight motor, which makes the headlight height adjustment you mentioned. [/ QUOTE]
As far as I know, the height adjustment is only available now in FK. He also supports h7. He's the father. But he is the most expensive. God damn you I couldn't get it anyway. Sorry for my site is burning :))
08.05.2020 15:22 # 19
emin1689
Well, my brother, or even if these angels come, I called on the stove in March said they will come out. May will still be over: /
