Does 307 knock on automatic reverse gear
08.05.2020 15:11 # 1
bugra_bk
I would appreciate it if you inform me that my friends are making a sound when 307s' auto is put into reverse gear.
08.05.2020 15:11 # 2
BAHTIYAR
sometimes it does not happen, but I usually do it in my car, considering it difficult to reverse gear, I consider it normal
08.05.2020 15:11 # 3
kaan__
that sound is normal, but there is a solution like this, if you stop the car, put it on the n position and apply the handbrake by pressing the brake, then if you put it in the p position, the gear will be softer and the sound will not be heard the next time.
08.05.2020 15:11 # 4
sometimes it does not, but in general it does. Especially if you throw it from D to R, the sound of the blunt is heard. There were all the auto 307s I got on. Frankly, I don't know if it's normal.
08.05.2020 15:11 # 5
berk2309
When you throw it in me, it sounds like a cut, a bounds, a boundary, a situation.
08.05.2020 15:11 # 6
metin
It happens to me too, but kaaan___ attracted my attention that my friend said, we will improve it even if it is in a bit of a try.
08.05.2020 15:11 # 7
endorphine
I was doing it if the vehicle was taken to the R position without stopping. Normally it doesn't.
08.05.2020 15:11 # 8
hantsome28
my 2004 model also does it in 307 ... i am thinking of changing the oil .. thereby i pass it because it passes..kronilk something is probably ...
08.05.2020 15:11 # 9
metin
[QUOTE = hantsome28] is doing my 2004 model 307 too ... I am thinking of changing the oil .. so I get rid of it ... I think something kronilk ... probably ... [/ QUOTE]
He says it is normal for him to hit hard when he shifts into reverse in his booklet.
but if "-", "snow", "sports" mode lights are on, it says there is an abnormal situation and it is necessary to go to the service.
08.05.2020 15:11 # 10
alisuat
sometimes I think it is norah, it is even normal when it shifts from 1 to 2 or when you downshift on the uphill triptronic.
08.05.2020 15:11 # 11
[QUOTE = endorphine] I was doing if the vehicle was put into R position without stopping. Normally it doesn't. [/ QUOTE]
When my friend read the article, a joke came to my mind.
Please don't be taken care of.
Hold on tight, Rocket Embarrassed
The base has bought a 0 km peugeot car. They said that the vehicle was guaranteed and that it should be brought to service if there was a failure.
Temel brought the car a week later, but in the gearbox. Service has repaired, sent the foundation. After a week, the Basic transmission came again. They repaired the service and gave him a master. They set out on the Basic Way with the Master.
The master asked - How is your car's gearbox broken?
Basic: -My servant. We take off with the first gear, accelerate, 2nd gear, 3rd gear, 4th gear, 5th gear, the speed is not enough, Rocket.
08.05.2020 15:11 # 12
[QUOTE = mustiii] [QUOTE = endorphine] I was doing if the vehicle was taken to R without stopping. Normally it doesn't. [/ QUOTE]
I swear what I said to you, I experienced the joke that you said last week. He said how the gears are passing on the road with our friend. He never used it automatically. I'm at the wheel, telling ours. Here P is parked, R shifts into reverse, N is empty, D is normal gear, huh I got bored you want to control manual gear, take this look, look at this side. At this moment we have 3 speeds around 100-110, I said if you knock forward 4 would be 3 if you pull back. and I added. Actually, when I got used to it, I said the most beautiful D and threw it into D. Turkish intelligence is ours, so now it is not wasted, did I say? I am looking at the road. Not only did we say that when he put his hand in gear, I saw R on the screen. I saw Yusuf on the windshield. Yusuf yusuf Embarrassed
As soon as I saw R, I pulled back to D immediately. Nothing happened from God. I said, what are you doing? You will embrace the transmission or you will make a package and send us to the other side. I pulled right, shouted a little, then the joke came to my mind. We came bye Gülme
Who is TEmel in the paragraph, I saw his truth Embarrassed
Note: Do not take friends whose name is Yusuf. It was used as a dilemma. the cover 2011-04-15 01:23:41
08.05.2020 15:11 # 13
F-Eren
[QUOTE = kaan __] that sound is normal, but there is a solution like this, if you put the handbrake by pressing the n position while you stop the vehicle and pull it to the p position, then the gear will be much smoother and the sound will not be heard next time. [/ QUOTE]
Master knows how to use automatic :)
08.05.2020 15:11 # 14
metin
[QUOTE = kapagan] [QUOTE = mustiii] [QUOTE = endorphine] I was doing it if the vehicle was put into R without stopping. Normally it doesn't. [/ QUOTE]
Note: Do not take friends whose name is Yusuf. Used as a dilemma. [/ QUOTE]
I'm always wondering what happens if I accidentally insert r into motion.
can you explain in a little detail?
I shifted to reverse gear, my tires were mass or something abnormal etc.
08.05.2020 15:11 # 15
Serhun
As I go forward in straight gear, it gets stuck back, but I have never pulled the clutch, tried it. As a result of this application, I learned that the sound of the parking sensor does not only work for parking. Sırıtma
08.05.2020 15:11 # 16
[QUOTE = text] [QUOTE = cover] [QUOTE = mustiii] [QUOTE = endorphine]
I can write this message Gülme thank goodness nothing happened. From the gravity of the situation, I could not elaborate, the yusuf was flying in the air. All I can say is nothing happened because I immediately withdrew, but I saw the text R on the screen. The vehicle continued to move forward at full speed.
08.05.2020 15:11 # 17
metin
May Allah have protected great history.
08.05.2020 15:11 # 18
F-Eren
[QUOTE = text] [QUOTE = cover] [QUOTE = mustiii] [QUOTE = endorphine] I was doing if the vehicle was put into R without stopping. Normally it doesn't. [/ QUOTE]
I think you will get the answer if you watch this video
[TUBE] haknxo5pme4 [/ TUBE]
08.05.2020 15:11 # 19
mehmetugur
friends, I just joined you. I have a 2004 model 307 xt otm I bought the car 2 months ago, I have never used otm before, I am not satisfied with the vehicle, I do not have any trouble, just like you said, the reverse gear shift was very hard, normal gear changes also changed according to the cold temperature of the air ... I went to the service. I said I want to change it, and I changed it by force .. the result is that the reverse gear shift has softened quite a bit .. I feel that it is only passing from 1 to two in other passes. It takes place between 2.7 and 3 thousand cycles .. pleasant driving for everyone.
08.05.2020 15:11 # 20
ADA PEUGEOT
Hi friends
ewet the correct automatic gearbox vehicles should stop completely then first, it should be taken to the park..this makes the knock down more downhill .. this is normal but it damages your car.
Apart from this, knocking or excessive shaking in gear shifts is not normal .. related axles and transmission or motor ears should be checked. Problematic parts replacement should not cause bigger problems later on.
It is not normal for the gearbox to fail at any speed, it is not a normal situation. When the ignition is turned on and the fault lamp goes out, it does not mean that the problem is solved. It must be checked.
Page : / 2
