Do You Want Your Console Clock to Burn Blue?
08.05.2020 14:11 # 1
cankurts
neccessary things:
6 1k resistors
6 wide-angle leds
1 perforated plate
cable, soldering iron and silicon gun ...
eminönal 2010-03-19 17:47:30
08.05.2020 14:11 # 2
HakanGokdemir
Is there any explanatory picture or explanation or did an error occur in the submission?
08.05.2020 14:11 # 3
Ozgur
I think an error has occurred. As if adding a picture
08.05.2020 14:11 # 4
HakanGokdemir
Yeah it came to me like that
08.05.2020 14:11 # 5
Murat
Obviously I would like, but how?
08.05.2020 14:11 # 6
cankurts
Can't you transfer the pictures to friends, can you help me?
08.05.2020 14:11 # 7
FTH
[QUOTE = cankurts] Or friends, I can't transfer pictures, can you help [/ QUOTE]
Göz Kırpma
08.05.2020 14:11 # 8
EminONAL
the pictures are ok :)
I have seen this work in another forum, are you quoting yourself?
08.05.2020 14:11 # 9
H-a-d-i
it was great. health to your hands
08.05.2020 14:11 # 10
cankurts
I added that these friends might work for you.
08.05.2020 14:11 # 11
EminONAL
it would be better if we mention it from the beginning, thanks for your sharing ..
08.05.2020 14:11 # 12
FTH
I would have done if I had 206 beautiful :)
08.05.2020 14:11 # 13
ACHTUNG
I guess it doesn't grin next to the red lighting
08.05.2020 14:11 # 14
yeniceri06
friends, I did it is not easy, there is nothing difficult, a little electronic information is enough, you connect 1 kohm to the LEDs.
08.05.2020 14:11 # 15
mamuli
It would be incompatible with the indicators so it would be nice if we could make the indicator lights blue :(
08.05.2020 14:11 # 16
EmRe26
Hello, I think I have not introduced myself before, but the friends who will make the leds should be white, not blue. The console's screen is already blue, remove the orange paper on the back, leaving only white gelatin paper. Give it a direct blue light. I have applied.If anyone wants, I can explain in detail. There is no need for this super flux.
08.05.2020 14:11 # 17
[QUOTE = EmRe26] hello I guess I have not introduced myself before, but the friends who will make the leds are white, not blue. The console's screen is already blue, remove the orange paper on the back, leaving only white gelatin paper. Give it a direct blue light. I have applied.If anyone wants, I can explain in detail. There is no need for this super fluxa, it is very nice to use led strip.
Hello Brother.
First of all I would like you to introduce yourself in the forum.
I would be delighted if you could explain in detail how to make the console clock blue in a convenient time as you described.
Thanks in advance.
08.05.2020 14:11 # 18
mod55
Nice app health to your hand :).
08.05.2020 14:11 # 19
EmRe26
Hello again I will explain in detail. I will explain according to 2002 model 206. I don't know if there are any changes in future models. First, lightly push the floor covering covering the clock console towards the glass and it will come off easily when you pull the side closer to the glass towards the top. There are 2 screws at the bottom of the console clock and remove them with a suitable screwdriver. It will come when you pull the console clock towards you. When you push the cable slot on the top in the white part and turn the black tab to the right side, you will get rid of the cables. Then we will dewam in an environment suitable for work. There are 3 nails on the top and sides of the watch, after you get rid of them, when you pull the black and white parts backwards. Let's go to the light part. Get rid of your nail on the lcd panel at the front. it will come easily. white and orange paper come out from under it. If orange works for you or you don't like the application you do, etc. Maybe it should be. We will use the white one. If you want to deal with superflux, I do not understand electricity, I think there is no need. Take from normal strip leds. Most of them are now double-sided adhesive. Org of console. You can easily turn the lights on at the top. Place the led strip in place of the eye line so that it hits the screen and at a right angle, if the angle looks upwards, it may make a shadow or the light distribution on the screen may not be homogeneous. You should pay attention to this. After aligning, the paste holds the tape comfortably. After it is firmly seated, insert the white paper in front of the LCD screen, then snap it on the nail. You can unplug the led strip from the previous round light sockets and connect it. I added a picture so much. I can answer if you have a question in your mind.
Uploaded with ImageShack.us
08.05.2020 14:11 # 20
EmRe26
the writings turned out to be yellow but it turns white. It is a very super image. In the future, I will get my hands on the dashboard and the air conditioning area.
Page : / 2
