Do you think 306 LPG fuel is too much?
08.05.2020 16:08 # 1
altay_26
Hello.
1998 model peugeot 306 XN 1.6, my 8 valve vehicle
& nbsp;
inner city km 28 Kr. LPG fuel is 11.2 liters per 100 km.
& nbsp;
23 Kr. LPG burns 100 km. & Nbsp; 9.67 liters as fuel. Or does it burn a little more?
08.05.2020 16:08 # 2
i think high brother 28 kr yaa & nbsp;
08.05.2020 16:08 # 3
How is the condition of the car? Are the spark plugs new or the air filter new? Do you use hard or soft? It all depends on the answer to the question.
08.05.2020 16:08 # 4
These figures differ according to the maintenance status of the vehicle. Even spark plugs are effective on this situation ...
08.05.2020 16:08 # 5
metin
my car 307 is automatic but it doesn't burn as much as you either use it very fast or there may be a problem with its engine. The quality of the bidet fuel is also important.
08.05.2020 16:08 # 6
altay_26
maintenance of the vehicle has just been done.
spark plug, spark plug cables, air filter and gasoline filter have just been replaced.
08.05.2020 16:08 # 7
metin
If you are using it that way, and if your maintenance is complete, it will be 9 liters + 1 liter in the city. It seems to me that
& nbsp;
our cecoli brother also has 1.8 sedans and he even burns between 9-10 liters in lpg.
08.05.2020 16:08 # 8
Then there is a problem. Almost the same models are our cars. Probably their engines are the same. I burn your extraterrestrial value in the city. & Nbsp;
& nbsp;
[QUOTE = altay_26] the vehicle has just been maintained.
spark plug, spark plug wires, air filter and petrol filter have just been replaced.
soft kullananlard am. [/ QUOTE]
08.05.2020 16:08 # 9
lpg de & nbsp; i think too high i burn 280 kr even when i use it with too much creep in gasoline.
08.05.2020 16:08 # 10
altay_26
friends, who knows the valve adjustment ranges, you have to do the suction, how many exhaust, how many valve settings, I guess.
08.05.2020 16:08 # 11
demirci
I also have 306 griffees, 1.6 lights up 28 kr, I agree with the friend .. A lot more than other vehicles but the car is going ...
08.05.2020 16:08 # 12
If you are using [QUOTE = text] in that way and your care is complete, it will be 9 liters + -1 liters in the city. It seems to me very much. burns between lpg.
& nbsp;
My text is not much below 10 liters in my city. It travels between 10-11. But when I press the gas in the series use, I would expect it to pass 11 naturally ... It is very important to set up maintenance and work in one place ... I easily get under 8lt. While I was freezing from Ankara, I was at the last warehouse I bought, after 110-120, and after getting closer to Istanbul, we gasped a little bit, I came to Kagithane, I changed friends, the average of 7.9 lt etc ...
CeCoLi 2011-09- 30 10:13:41
08.05.2020 16:08 # 13
Mustafaserefli
1995 model 306 1.8 SR & nbsp;
LPG KIT: Stefanelli Sequential system (Installation date March 2011)
did not keep any adjustment after installing the gas system.
Current situation.
Fuel Consumption: 100 Km for the city. 13.4 Lt (6 measurements day and night)
& nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; Out of the City 100 Km. 10 Lt. (Gebze outlet ankara entrance half tank in gasoline)
Traction has dropped. (We boarded 5 people at once and got disgraced on the slope)
Shudder and unevenness in idle throttle (like no shudder in gas)
Excessive sound in engine.
Recommended and done for these troubles:
Clutch pressure pad replacement,
Circulation belt replacement,
boron additive,
Spark plug cleaning, (Engineers said the engine has no problem.) (Or do I normally think everything is wrong?)
Regards, < / div>
SIGNATURE: Mustafa ŞEREFLİ.
My Blood Group (A RH +)
08.05.2020 16:08 # 14
assat76
The ignition coil can also cause this. If it ignites the ignition, it will both decrease from traction and increase fuel.
08.05.2020 16:08 # 15
insomnia
my car is not fitted with gasoline and gas at all.
08.05.2020 16:08 # 16
The number you call for a front-wheel drive car would be good if you review the high pitch system and the LPG settings. fuel.
08.05.2020 16:08 # 17
Mustafaserefli
Thank you so much for the support.
After replacing the spark plug and cable, I will write the situation here again. By the way there is a bosch platinum spark plug for lpg. Single quotes. i will try it. .
My Regards
08.05.2020 16:08 # 18
Ucyuzalti
My vehicle burns around 18 kr. Please give a little out of town & nbsp; I guess, you went here on the road like an important highway, on the road to the village, on the winding road, these will affect your fuel values.
08.05.2020 16:08 # 19
oguzhandincel
My car spends fuel close to your values, but it's automatic. Manual gear is like the vehicle has a problem. You have to try what your friends say.
08.05.2020 16:08 # 20
Mustafaserefli
First of all, Good Holidays.
We have changed spark plugs. Single nail Spark plug. traction has improved. Gas adjustment was made again. But I don't like it. This time the car stopped shaking when it cut off gas. It clears when you press the clutch. There is no problem with gas. & Nbsp;
Now I will have a gas adjustment at a different place. & Nbsp;
