Do you have a tape recommendation?
08.05.2020 18:55 # 1
herry
I decided to buy a Pioneer tape. I am waiting for your suggestions.
http://www.pioneer.eu/tr/products/25/121/61/overview.html
edit: link
herry 2014-12-05 22:40:27
08.05.2020 18:55 # 2
suppor
Master, I bought 200 tlye mhv 150 series, I am very happy without the CD, single amp output mono anti cabin, 4 sony 3-way hoperlor even enough to listen to me more than enough.
08.05.2020 18:55 # 3
Alicilik
[QUOTE = herry] I decided to buy a Pioneer tape. I am waiting for your suggestions.
edit: link
High outputs of all Pioneer models are 4 * 50w. The lowest model has a double RCA of 2v. It is used as Sub.
As the model increases, another pair is added. You can use it as on and back / sub. If you take the model to 5000 series, these outputs will be 3 or 4 volts, which is important for quality. In the 7000 series, there are 3 pairs of RCA 4v RCA outputs. This allows you to get a very high quality sound in the possible sound system.
Apart from this, depending on the model extension SD-BT-UB
Model with SD sd card slot
BT bluetooth kit model
Classic model with UB USB
some models may meet multiple features.
Mixtraxx allows you to change the screen and button colors depending on the song or independently.
I recommend you to choose models with Bluetooth. I put it in my father's car and even has a title in the forum. I used the 6550BT model, both mixtraxx and 2v double RCA output. I also connected the tape to Vibe liteair optisound 8 slim active sub.
This year, the 6650BT model was released and I put it on a relative's vehicle. The only difference between 6550 and panel is that it has small chrome details and is more chained.
Using Bluetooth is very enjoyable, you can easily make phone calls and listen to music video etc. on the phone.
I prefer the USB output from the back. They can crash in the USB use and rent the socket on the panel. People have witnessed many times and it costs money. You can easily fix this with an extension from behind.
If you think of the sound system, 2v single double RCA will work for you, but for a sound and quality sound, I would recommend 3v and 3 way RCA. But no, I am not going to use the amp plug, the direct tape outputs are enough, even the lowest model gives the same quality sound.
Whatever your expectations and bounds move, I say.
I use the 9350SD, I bought it the year it came out and I still use it. There is no lack of bluetooth, it is a very good quality and useful tape.
08.05.2020 18:55 # 4
herry
[QUOTE = Buyer] [QUOTE = herry] I decided to buy a Pioneer tape. I am waiting for your suggestions.
edit: link
I swear what you called Ali'cim. what you wrote was very useful. I liked the pioneerda mixtraxx event very much. IT thing is as beautiful as you said. I have a small sound system, if I enlarge it in the future, I want to buy a tape that can meet the expectations. I stayed between deh x8500 bt and deh 9500bt, it has almost the same features, with sd card, bt feature, dual usb (from the back), iphone support and the technical features you call, there are differences in the outer designs, even though the two models are similar, 85 more The sport stands, it has sharp lines, more lighted fln. 95 heavier and simpler. By the way, I have 16`` hertz speakers and tweeters on my front doors, 10 '' pioneer on the back because the speaker is very small. In the trunk, it supports the JBL bass amplifier and subwoofer. I can't do much more anyway, the place to put speakers on the back doesn't take the original places bigger than 10cm in them, maybe I will enlarge the amplifier in the future, and strengthen the speakers on the front doors. and there is a model tape called deh 8400 bt. What can you suggest among the model I mentioned?
08.05.2020 18:55 # 5
ihsanozlesmis
edit: link
Until now, I have used Sony, Kenwood, Pioneer, Jvc ... Which is superior, I say JVC without thinking about it. The rest ... Mine is just a recommendation, but I would definitely recommend it. JVC KD-R426 Get Zero 200-250 Murtaş Guarantee No Problem ...
08.05.2020 18:55 # 6
Alicilik
The characteristics of 8500 and 9500 may be considered the same. I don't like the cd eye on the panel because it makes the screen look very small. So I bought 9350sd in 2011. If bluetooth was not common then, I would give the statement.
The 8400 old model may only have the difference of iphone and android compatibility, and the visual difference is the same except for the same 4 * 50mosfet output 3x 4v RCA sd card bluetooth etc etc
I will buy the 9500BT if I can, but I can't bend the tape in my hand because it is the most stylish and polite tape of pioneer. It is reminiscent of the 9400 and prs series.
08.05.2020 18:55 # 7
tigerland
1400ub is good ipod i phone compatible ipad with plug and play like indash bidet tablet holder continue. open the movie directly into the system, open the map, open the map, cd sd card etc. direct garbage .. direct playist control etc. definitely my advice. :) tigerland 2014-12-07 00:58:41
08.05.2020 18:55 # 8
tigerland
youtube facebook open whatever you want, open whatever you want, listen to the system, listen to it .. also listen to it at the same time as the bluethoth, do not end your charge charge, listen to it with a cable, get a charge for 1 hour, the device is full :) the phone does not have the luxury of hearing it. I think ub has a price like 249 TL .. tigerland 2014-12-07 01:04:02
08.05.2020 18:55 # 9
herry
[QUOTE = tigerland] 1400ub is good ipod i phone compatible ipad and plug the cable as indash I use bidet tablet holder continue. open the movie directly into the system, open the map, open the map, cd sd card etc. direct garbage .. direct playist control etc. definitely my advice. :) [/ QUOTE]
I do not have full TV navigation in my car already installed indash on the device, I even connected ps2 to the insash's screen from the torpedo :))
I'm going to change the style on the console, so I don't have to connect the tablet, I'm a little bored with the screen heat. I just want to wear a simple pioneer and just listen to music.
08.05.2020 18:55 # 10
herry
[QUOTE = Receivability] The characteristics of 8500 and 9500 may be considered the same. I don't like the cd eye on the panel because it makes the screen look very small. So I bought 9350sd in 2011. If bluetooth was not common then, I would give the statement.
your device is also very stylish. The only difference is that they don't have BT and they take USB input from the front. The bt feature is a beautiful thing, of course, but it is not worth spending the model on your hand, I think use it as you work.
As you said, I think about 9500. I also noticed that the front input of the cd is blowing up the screen, it is very important. and it looks like 8500 light toys. For example, your tape is like a plain 9500.
08.05.2020 18:55 # 11
tigerland
[QUOTE = herry] [QUOTE = tigerland] 1400ub is good ipod i phone compatible ipad plug the cable, use it like indash bidet tablet holder continue. open the movie directly into the system, open the map, open the map, cd sd card etc. direct garbage .. direct playist control etc. definitely my advice. :) [/ QUOTE]
What is the brand when it comes to the last system?
08.05.2020 18:55 # 12
herry
[QUOTE = tigerland] [QUOTE = herry] [QUOTE = tigerland] 1400ub is good ipod i phone compatible ipad plug the cable like indash I say bidet tablet holder continue. open the movie directly into the system, open the map, open the map, cd sd card etc. direct garbage .. direct playist control etc. definitely my advice. :) [/ QUOTE]
http://www.rsteknoloji.com/necvox-dva-6806hd-7-ındash-navigasyonlu-multimedya-cihazi,pr-869.html
08.05.2020 18:55 # 13
Alicilik
[QUOTE = Henry]
Unfortunately, there were not many variations when I received the tape. I don't know if there was a Bluetooth model. The sd card was in fashion. In all of the USB, it was the old one, then when the problems in these ten panels disappeared, they canceled the 8-way key first, and then moved the USB backwards. 9500bt nice choice
As the audio outputs, I only use the amp output so it is very satisfying because it is 3-way 4v. The tape I'll get is already the same. If there is a lot of trouble, I will enter one bluetooth module from aux.
08.05.2020 18:55 # 14
herry
[QUOTE = Acquisition] [QUOTE = Henry]
it looks very stylish, by the way, your car is clean and tidy, maahallah Clap
08.05.2020 18:55 # 15
tigerland
[QUOTE = herry] [QUOTE = tigerland] [QUOTE = herry] [QUOTE = tigerland] 1400ub is good ipod i phone compatible ipad plug the cable as indash, bidet tablet holder continue. open the movie directly into the system, open the map, open the map, cd sd card etc. direct garbage .. direct playist control etc. definitely my advice. :) [/ QUOTE]
nice device but when you disassemble this tape and plug in pioneer, it would be incredible difference if you used pioneer indash you know the difference. features are nice but pioneer connect see the difference :) 5.1 sound dolby digital vs.vs pioneer rms is very good from this ..
08.05.2020 18:55 # 16
herry
Yes, as I said when buying necvox indashi, I bought it for its features, although the pioneer indashle was at the same price, its features were attractive, and pioneer was of course noticeably higher. I am satisfied with the multimedia event, now it is simple indash :) indash is a nice event, but when the screen is on, it turns off the heating pads in 206.If it is in the pioner, if it is in necvox, the heating pads will be closed, maybe it will be better in summer screen event :)
08.05.2020 18:55 # 17
herry
I decided on the 9500BT, I was looking for an affordable price, and a model called 9650BT came out. I'm confused is this a higher model, do you know what the difference is? I wanted to be the last model when I bought it, which one is new?
Shocked
08.05.2020 18:55 # 18
erdemchetin
Take a look at the navitech nx 145r model
