do you go through the examination? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 17:14 | # 1 |
206x-line |
| 08.05.2020 17:14 | # 2 |
Xenons are not past, I do not know you in Izmir
| 08.05.2020 17:14 | # 3 |
ceiling cover and angels let me know & nbsp;
| 08.05.2020 17:14 | # 4 |
ufuk91 |
I know that if you did not operate the vehicle in 2 colors after the roof was covered, it would not pass. Unless your vehicle is already black. Angels do not pass. I don't think the others are important, they don't get stuck in the movie or something.
| 08.05.2020 17:14 | # 5 |
_semihk_ |
there is 30% incident in the roof covering ... if there is 30% more color than the license color, it will not be in the vehicle. |
| 08.05.2020 17:14 | # 6 |
_semihk_ |
headlight height adjustment is working, you will have no problem other than exhaust
| 08.05.2020 17:14 | # 7 |
outlaw |
Angels spring gear pedal does not cause trouble, but the ceiling foil distressed exhaust pattern is already offside by itself.
| 08.05.2020 17:14 | # 8 |
ufuk91 |
teacher ceiling is already 30% so
| 08.05.2020 17:14 | # 9 |
I have a remus exhaust & nbsp; when the vehicle is late, my teacher .. |
| 08.05.2020 17:14 | # 10 |
206x-line |
exhaust is not too exaggerated, if there is a problem with the silencer, I would appreciate it if the original exhaust does not stop & nbsp; I hope the ceiling won't be a problem
| 08.05.2020 17:14 | # 11 |
Dear friend; ceiling covering: no defect counts pedal and knob: no defect counts < / div> windows film later: slight defect lens headlights: no defect counts if there are xenon headlights, the automatic height adjuster and headlight washer system must be installed and if you have it installed later Due to the change in technical specifications, you need to have an inspection project done. Adem ÇINAR
| 08.05.2020 17:14 | # 12 |
meanwhile, for the springs, use the small diameter during the inspection of the tire diameter & nbsp ;;) & nbsp; (no problem if the tires do not rub in what we call cross-test)
| 08.05.2020 17:14 | # 13 |
206x-line |
The height adjuster does not work in Angel headlights disabled. 13:29:09 editdat a> edited>
| 08.05.2020 17:14 | # 14 |
Exhaust silencer plug and go. If the left and right do not blow, it will pass
| 08.05.2020 17:14 | # 15 |
cey cey |
I am always going with Angel, I wear a yellow bulb and tickle the headlight setting does not work up down the satin.
