do tire sound
08.05.2020 18:17 # 1
sosyete_60
hello friends 2004 model 307 there are balls in the gearbox of my gasoline car front foryo balls have always been changed, there was no hum, we changed the tires of my car and made rot ballas now it is buzzing when the flat tire goes flat thin tires 205/55/16 pirelli cintirato p7 & nbsp; about 15 months old Do you think the tire is made of rubber or ball?
08.05.2020 18:17 # 2
Brk44
If it is an unusual hum, I don't think it will be tires, but don't risk it anyway, show it to somewhere.
08.05.2020 18:17 # 3
tongucuk
snow tire makes it sound if normal wires are broken in normal tire
08.05.2020 18:17 # 4
qqyyxx
it will be a little cursory but the pirelli tire makes the sound aga. & nbsp;
08.05.2020 18:17 # 5
barishrocker
I went to bridgestone because I squeaked to the parking lot and bought a tigar (michelin subsidiary). Good quality and soft tire. Soft rubber for our cars is good. Pirelli is also hard ..
08.05.2020 18:17 # 6
Alicilik
The ball incident happened to me. The aircraft engine in the 90-120 vehicle was activated, it sounded like that, but after 120 we were returning to normal diesel sound. Listen to the steering wheel and the vehicle, sound or vibration. The ball makes a lot of noise due to vibration.
08.05.2020 18:17 # 7
furkanyakar
they both do. it's easy to lift the cart and spin the wheels by hand. tires if wheels spin comfortably ... be past :)
08.05.2020 18:17 # 8
kivanc
[QUOTE = Buyer] The ball thing happened to me. The aircraft engine in the 90-120 vehicle was activated, it sounded like that, but after 120 we were returning to normal diesel sound. Listen to the steering wheel and the vehicle, sound or vibration. The ball makes a lot of noise due to vibration.
Did you remember the sound in the car ali :)
08.05.2020 18:17 # 9
Alicilik
[QUOTE = kivanc] [QUOTE = Recipient] Ball event happened to me. The aircraft engine in the 90-120 vehicle was activated, it sounded like that, but after 120 we were returning to normal diesel sound. Listen to the steering wheel and the vehicle, sound or vibration. The ball makes a lot of noise due to vibration. Brother yours is a different event. Your tires also serve as abart exhausts. Reviews
08.05.2020 18:17 # 10
barishrocker
Just like the abarth :) tires will work so well ..
08.05.2020 18:17 # 11
kivanc
No pilgrims bearing :) tires do not sound that much :))
08.05.2020 18:17 # 12
ahmet_bjk
If the sound started to come after these operations and the rot balance was adjusted, the reason for the sound is not the tires.
08.05.2020 18:17 # 13
ahmet_bjk
You were driving up to 90 cars and planes after 90 "LOL"
08.05.2020 18:17 # 14
sosyete_60
friends, what will I say to the balaman today, but all the balls in the gearbox have changed before it changed, but when you lightly break the steering wheel, it would be humming without breaking it now: D but we changed the tires and started doing it after that, apart from our position, but when I changed the pressure pad, I put it in a new box for the gearbox. I put it in 2 liters of oil.
08.05.2020 18:17 # 15
BG307
[QUOTE = sosyete_60] friends will say what I will go to the balasman today, but all the balls in the gearbox have changed before I change it. I put a borpower for a box of gearbox, I completed 2 liters of oil. Do you have a certain ratio of it? When using in the gearbox, I put 250 ml of boron 1750 oil [/ QUOTE]
Did you put boron in transmission oil?
08.05.2020 18:17 # 16
sosyete_60
yes I put the transmission pipe
08.05.2020 18:17 # 17
furkanyakar
I think it won't be a problem. The amount of oil to be received by the transmission is clear and proportioned accordingly.
