do I have an oil on the engine?
08.05.2020 15:53 # 1
mehmet eren
friends, there is a lubrication on the side of the engine of my vehicle, I am not solved, I am waiting for your answers
I 1.Resim
I'm shown by # 2
lower sides of the engine.
08.05.2020 15:53 # 2
If it is worn out, it will be thrown from the crankcase gasket.
08.05.2020 15:53 # 3
mehmet eren
okay teacher thank you bakıcam.I need to tighten the seal? mehmet eren 2011-07-24 14:34:15
08.05.2020 15:53 # 4
[QUOTE = mehmet eren] okay teacher thank you my caregiver.Is it necessary to tighten the seal? [/ QUOTE]
It is not very expensive, I say replace the gasket. Of course, you need to make sure you throw it out of the gasket. A show first, though.
08.05.2020 15:53 # 5
mehmet eren
The sealing parts of the engine are dorder:
Uploaded with ImageShack.us
2.cont to
3.cont to
At the bottom of my vehicle, there are traces of lubrication, we are in the home country, we can not look at it because we are not a master.
08.05.2020 15:53 # 6
Kemanyak
My friend is throwing oil out of the top cover gasket. If the above screws are not tightened to the proper torque, replace the seal.
08.05.2020 15:53 # 7
mehmet eren
Can I damage the oil from the top cover gasket, it can do much damage? First, as I said, there is no master as I said.
08.05.2020 15:53 # 8
vbmaster
Confirm the oil of the teacher, there is little missing, and there is not a possible problem, but if there is a bite, you can squeeze it, but I think it will be the solution. nevertheless, after spraying, clean the oil from the sprays, which reduce the oil, clean it beautifully.
08.05.2020 15:53 # 9
mehmet eren
Thank you for the answer, my teacher, I check the oil every day.
08.05.2020 15:53 # 10
Kemanyak
I use WD 40 called spray but you can use any rust solvent spray on the market. When it comes to the issue of harm, it reduces fat and requires you to control it, but it doesn't do much.
08.05.2020 15:53 # 11
Alparslan
Friends, there is a wurth lining cleaning spray for cleaning the engine oil, it is very effective and I recommend cleaning the engine very well.
08.05.2020 15:53 # 12
mehmet eren
I will wait until my father comes home, I always check the oil, I give a clear answer on Monday
08.05.2020 15:53 # 13
I think that what happens on the upper side of the engine comes from the valve cover gasket, which is seen by the transmission. Because the sump side looks dry. It may leak from axle times. If it is controlled thoroughly, it is understood exactly what is where ...
08.05.2020 15:53 # 14
mehmet eren
If the heat leaking from the transmission can be excessive damage, I do not use the vehicle continuously. Thanks to the ways. Thanks for your answers.
