Do I find the original 406 Amphitheater |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 15:57 | # 1 |
Bavik |
I have asked about 406 JBL amps, they said there is a factory outlet. If I change the tape and cancel the amplifier or do I find a different amplifier from the same amplifier or do you have any information on the prices thank you |
| 08.05.2020 15:57 | # 2 |
Let's meet first, fuse; Let's not close synergy I http://forum.peugeotturkey.com/forum_topics.asp?fıd=22&title=yeler%ddm%ddz%dd-taniyal Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better. 1.- Your name and surname: 2.- Your age: 3.- Your vehicle (Brand, model): 4.- Your hobbies: 5.- Your profession: 6.- Where did you hear the site: 7.- Your Blood Group: 8.- Your horoscope: 9.- The team you support: 10.- Which county or province are you in: 11.- Your MSN address: Thank you for your attention. Peugeot Turkey Fun Club Management Www.peugeotturkey.co & www.peugeotturkiye.co I |
| 08.05.2020 15:57 | # 3 |
hcbank |
com also sells a man with money Says 250tl
| 08.05.2020 15:57 | # 4 |
Bavik |
wuuuw 250 tl is a bit too much
| 08.05.2020 15:57 | # 5 |
I think 250 TL wanted 780 TL for the zero of cheap amps in the service, the publicists do not fall below 400 TL in Ankara. If you find a decent electronicist, it can be repaired, it is not a very complicated device, probably the automatic sound control circuit is burned, this is the most common problem.
| 08.05.2020 15:57 | # 6 |
Bavik |
[QUOTE = mimitt] 250 TL I think they wanted 780 TL for the zero of the cheap anfi in the service, the publicists do not fall below 400 TL in Ankara. If you find a decent electronicist, it can be repaired, it is not a very complicated device, probably the automatic sound control circuit is burned, this is the most common problem. [/ QUOTE] At that time, I went to somebody, I went to a couple of electronics, the room couldn't solve properly, there are 600w amps in the alpine. ![]() |
| 08.05.2020 15:57 | # 7 |
The original amplifier of the car can get louder with 8 channels of other amps but you can not catch the same acoustics.
| 08.05.2020 15:57 | # 8 |
Bavik |
You're right, it looks like I'm going to get a complete overhaul with this going, but let's see it as soon as possible.
| 08.05.2020 15:57 | # 9 |
Have you looked at the junkyards (star industry) site, though electronicists come and unload the vehicles but try a chance :). |
| 08.05.2020 15:57 | # 10 |
Bavik |
I did not look at the stars, but there are lots of prices, I think about going tomorrow today, but you are right, they leave the skeleton of the car and leave :)
| 08.05.2020 15:57 | # 11 |
You can buy cheap with tight bargains on the star.
| 08.05.2020 15:57 | # 12 |
Bavik |
let's try then
| 08.05.2020 15:57 | # 13 |
Bavik |
What if I just change the tape from the tape, I have the mind, how do I get the installation from the pionner or navitech that gives 4x50 w output, i.e.
| 08.05.2020 15:57 | # 14 |
You will need to connect the mid-treble kit on the front windshield and the bass on the door together, and the same way you can feed 2 speakers from a channel, so a solid tape can handle it because the car's amp output is 8 * 20 or 25 watts. but my advice to share my own experience is to have the amplifier repaired and support the columns in your vehicle with more up-to-date jbl products. I had put a for-x tizz under the windshield in the original amp + jbl GTO 8628 + jbl gto 6528 system, but in the front, the sound was very thin on the front, instead I removed the 6528 and put a 16 component. (jbl gto6508c) the result was more than satisfying for me. once you start it, the devil nudges, after all, I took a mono amp in the car and put a 30 cm sub :) Another event is to start the event with a new main unit as you said. If the things are insufficient (it will come after a while), new columns can be taken and installed. The decision is yours.
| 08.05.2020 15:57 | # 15 |
hcbank |
brother ank sells someone in the tape tape changer and your anfi 400 tl say a talk if you want to advertise on .com no 54489720 Look at the pictures.
| 08.05.2020 15:57 | # 16 |
Bavik |
look at the announcement you said that you are your sago.
| 08.05.2020 15:57 | # 17 |
original amplifier original tape e speaker support i think the best is if you have visual obsessions like me, there is a gap on the screen when you disassemble it, the attached tape stands upwards, the job deficit does not look nice to me :) The products I named are compatible with the car and the amplifier, pay attention to 2ohm.
