dıttttt tone
08.05.2020 16:32 # 1
furkan111
friends 2006 model 206, when I open a contact between them, there is a tough sound, why does anyone have any idea, oil is more than normal water normal service time?
08.05.2020 16:32 # 2
rifatseker
Turns off the ignition and removes the key and removes it after a certain period of time.
08.05.2020 16:32 # 3
furkan111
Exactly, but there is always a meaning, let's see who knows?
08.05.2020 16:32 # 4
If you connect it to the computer and see it, I wish everyone has this problem :)
08.05.2020 16:32 # 5
djchaos
If it does in the winter, ice alert or other failure is fuel, where you park your battery is downhill, the oil may not reflect some faults on the screen. Do not run as soon as you plug it in, plus connect it to the computer and get a thorough check up.
08.05.2020 16:32 # 6
furkan111
I think I noticed that the oil is pouring out, I think I have paid attention to the bottom of the car, it leaves a little oil.
08.05.2020 16:32 # 7
Meric42
Furkan brother 2005 I have a partner. I had the same issue in a couple of friends, we had the same problem and we added glass water. the sound was cut off ... strange nonsense, but split
08.05.2020 16:32 # 8
yavuz25
[QUOTE = Meric42] furkan brother 2005 I have a partner. I had the same issue in a couple of friends, we had the same problem and we added glass water. The sound was cut .. strange nonsense, but split: D [/ QUOTE]
even the sound came again. My glass water was finished. Big smile "title =" Big smile "/> interesting.
08.05.2020 16:32 # 9
Meric42
:) I haven't had any sound since my son. & nbsp;
08.05.2020 16:32 # 10
yavuz25
[QUOTE = Meric42] :) I haven't had sound since my son. & Nbsp; [/ QUOTE]
Let's say, let's say no other problem. "Smile"
08.05.2020 16:32 # 11
Meric42
[QUOTE = yavuz25] [QUOTE = Meric42] :) I haven't had sound since my son. & Nbsp; [/ QUOTE]
Mashallah: D
08.05.2020 16:32 # 12
furkan111
I will try it really or very interesting ... we have learned something else
08.05.2020 16:32 # 13
06OzGuR06
[QUOTE = Meric42] furkan brother 2005 I have a partner. I had the same issue in a couple of friends, we had the same problem and we added glass water. the sound was cut .. strange nonsense, but split: D [/ QUOTE]
I think it's strange and nonsense, it's nice because glass water is very important, for example, cruising on the road
on the go & nbsp; If the windshield suddenly turns off mud, we will not see anything, it is life threatening. "Smile" So
glass water is very important "Smile" & nbsp; Let's check once a week. Especially before we go long, let's flush the glass
water. "Wink" Reviews
08.05.2020 16:32 # 14
yavuz25
[QUOTE = 06ÖZGüR06] [QUOTE = Meric42] my furkan brother 2005 I have a partner. I had the same issue in a couple of friends, we had the same problem and we added glass water. the sound was cut .. strange nonsense, but split: D [/ QUOTE]
water. "Wink"
makes sense in myself
"Thumbs < br>
08.05.2020 16:32 # 15
ares2626
I have 307, I hear the same sound when the engine oil level decreases and the screen says that the engine oil is low, the motor oil and meat are friends, look, if you want to make sure, it will be a little harder to turn the curve or make a hard turn.
08.05.2020 16:32 # 16
yavuz25
[QUOTE = ares2626] I have 307, I hear the same sound when the motor oil level is low and the screen says that the motor oil is low, the motor oil and meat is my friend, if you want to make sure, you will get a little hard turn or change the solution. seems less like ozmnsensore [/ QUOTE]
warning sound or indicator lamp is not lit on the screen while sound is heard, only one beeping sound is periodically. "Wink"
08.05.2020 16:32 # 17
yavuz25
[QUOTE = ares2626] I have 307, I hear the same sound when the motor oil level is low and the screen says that the motor oil is low, the motor oil and meat is my friend, if you want to make sure, you will get a little hard turn or change the solution. seem less like ozmnsensore [/ QUOTE]
why is your engine oil running low? "Shocked"
08.05.2020 16:32 # 18
ares2626
Well, my brothers, the master, said that he will explode with 250 bolts, but he said I will leave the car, but he said 1 day.
08.05.2020 16:32 # 19
yavuz25
[QUOTE = ares2626] I swear he said that it was one of the places that were tightened with bolts, my brother said that the master 250 will explode, but I will leave the car for 1 day. I couldn't understand if you describe the photo or something. Maybe your solution is reserved. "Wink"
08.05.2020 16:32 # 20
06OzGuR06
I think it is missing from the seals. As a result of overloading, the seals are burning, and also the leaking oil smells when it touches the hot engine. "Smile" 06ÖZGüR06 2012-01-25 15:24 : 49
Page : / 2
