Dittt ditt dittt sound from the contact
08.05.2020 17:11 # 1
tafo
Friends 206 gti, when I turn on the war contact, dittt dittt ditt sound gelio three times later, I cut the car in the same way and made the contact again. can you help warsa know ???
08.05.2020 17:11 # 2
Barut
Do you have lpg in your vehicle
08.05.2020 17:11 # 3
tafo
yes brother war & nbsp;
08.05.2020 17:11 # 4
Barut
If the petrol warning light is on, it usually does it, when the gasoline is low, I guess you have little gas in the tank because lpg is in your vehicle.
08.05.2020 17:11 # 5
tafo
Gasoline usually stays on the quarter tank, I haven't lit the light, so I don't guess it is from it & nbsp; "Disapprove"
08.05.2020 17:11 # 6
phoenix.1905
My friend, that sound comes from the Lpg kit. If you change the lpg filter, it won't sound. They go to the LPG and change the filter for 30-50 TL. If the setting is bad, they make adjustments. Sound is cut off .. & nbsp;
08.05.2020 17:11 # 7
tafo
Thank you bro, I have been crazy for 3 days, I took the electrician, did not understand the room, I will go as soon as possible & nbsp; "Wink"
