Display time date setting
08.05.2020 20:55 # 1
Turgut58
pejo 308 dab screen tape. But I need to set the time and date of the car. How should I follow the road
08.05.2020 20:55 # 2
some models support, some don't support teacher. You have to mix it thoroughly in the settings section.
08.05.2020 20:55 # 3
maximusti
If the attached tape is oem, I think it has the relevant setting in the settings section,
if the worst original tape stands, you can plug it in and make adjustments and remove it back,
alternatively, you can set the clock to 00:00 by removing and plugging the pole at 00:00 at night but the date remains :)
08.05.2020 20:55 # 4
Turgut58
there is setting but I couldn't find the car's time date from there. The tape is controlled from the cufflinks of the vehicle.
08.05.2020 20:55 # 5
Gokcesel
Hodja, there will be an application such as vehicle information in the tape menu. I have an OEM double tape in my vehicle as well.
08.05.2020 20:55 # 6
Turgut58
unfortunately i couldn't find it
08.05.2020 20:55 # 7
pusutr
There is info in the settings section. It may be indicated by i. When you click on info, the menu related to vehicle settings is reached. From there, the date and some settings can be made.
It is me too ..
