Display problem |
| 08.05.2020 19:48 | # 1 |
| 08.05.2020 19:48 | # 2 |
Or can I repair this screen?
| 08.05.2020 19:48 | # 3 |
Cyrus35 |
While taking it, take 3 lines of screen and activate the com2000 key. It is very easy to remove and install. Also, the lights are on, the information is not visible, or there is no reaction, such as light and writing, because they have sensory bulbs and they can explode over time. ! |
| 08.05.2020 19:48 | # 4 |
During the day, the image looks very careful, but it is not even noticed without care, but there is no image at night
| 08.05.2020 19:48 | # 5 |
Cyrus35 |
If the lights are on, when you turn on the ignition and turn on the parks, the screen lights up and the information is not read. But if there is no light, replace the bulbs and check again. This will appear when you pull the hat carefully and slowly upwards from the back of your four-button key, then you can lean on the back of the screen and see the sockets from the accessories, such as a micro bottomless bulb and change it yourself.
| 08.05.2020 19:48 | # 6 |
No, it's totally dark
| 08.05.2020 19:48 | # 7 |
Yes, as you said, teacher, there are 3 bulbs in 3, when the sun shines on the screen, it shows very clearly.
| 08.05.2020 19:48 | # 8 |
Cyrus35 |
You can take the accessories out of the accessories and squeeze the bulbs with the help of pliers and replace them without breaking them.
| 08.05.2020 19:48 | # 9 |
Thank you, my teacher, when the bulbs changed but it was stuck in my mind on 3 lines on the screen again, temperature average fuel consumption or something
| 08.05.2020 19:48 | # 10 |
OguzhanKucuk61 |
There is a bulge under the mirror for the temperature indicator, if it does not have to be 50 lira, you should be informed
