DISPLAY
08.05.2020 16:43 # 1
teoman_40
Friends belong to my car & nbsp; 3 lines of the screen are erased too unreadable in hot weather, everything is normal in cool and cold weather. Do you think it should change or is there anything to do?
08.05.2020 16:43 # 2
istanbullu_3886
The room will be the same after a certain period of time, even if you received a new one in 307.
08.05.2020 16:43 # 3
teoman_40
So you say this way continue :)
08.05.2020 16:43 # 4
Ozgur
[QUOTE = istanbullu_3886] Even if you get a new one in 307, the room will be the same after a certain time [/ QUOTE]
If you install the 206 screen, it will not be the same. The liquid crystals of the 307 screens are problematic. The men continued to produce in the same way. The procession turned out to be problematic. But there is no click on 206 screens. I would say if you can get 206 screens.
08.05.2020 16:43 # 5
acad
normal friend, continue
08.05.2020 16:43 # 6
heffera
it is not caused by heat. it is in cold weather ...
08.05.2020 16:43 # 7
nkre51
friends, there is no screen fading problem, I have the screen
307 compatible, hot-fading lamps are solid
plug and play
08.05.2020 16:43 # 8
selkentli
There is also the same problem in my mind, I think it resolves when I change the bulbs, examine how the screen is disconnected from the net, if I do not have a predisposition to electronics, I will get help from a friend who understands .. Free master understands this approach to him :))
08.05.2020 16:43 # 9
Ozgur
The bulb does not improve with friends. The trial is free. I hope you can handle it. Free 2012-05-12 13:24:18
08.05.2020 16:43 # 10
It does not improve with bulb replacement, I have not tried, now if I make a bidet led, I will share the result
08.05.2020 16:43 # 11
ahmet_ankara29
yes the same problem exists in me: ((
08.05.2020 16:43 # 12
selkentli
I lede lede :))) & nbsp; I have solved my problem for now, but the screen is affected by the sun because it is a "liquid" screen, it will be a problem again in the future. The best solution, because now I have installed the led by myself and I do not have any expenses :), if you understand the solder from the electronics, install a 3-chip white led.
08.05.2020 16:43 # 13
toga406
There were digital watches in the past. They would have gone on the screen in the same sun.
Here is the thing that you have complained about in the 307s. Unfortunately, they are designed for them because they are so cold.
08.05.2020 16:43 # 14
Cmoss06
Unfortunately this is a keronic problem in the 307s, but of course the air temperature is heating up the rear bulb screen, but maybe if you cancel the bulbs and install a wide-angle daylight & nbsp; mushroom led, maybe a little problem.
