Disc Pad Replacement
08.05.2020 20:21 # 1
CemDemiral
Greetings friends good forums ...
1 week ago I changed the front brake discs in Göral service discs, aftermarket linings, I bought the original Peugeot brand logo. Although it is 1 week, the brakes are very soft compared to the past, and even though I press down to the root, it slows down but I made a sudden brake test at 110 KM speed today but it stopped very late compared to the old car God bless I was afraid that this car would not stop in an emergency. They got used to 1-3 days, they said you have to make 250-300 km for some acquaintances, but I already travel 60 km daily, just go to work, this is 420 km in a week, except for sightseeing.
If you give some ideas, I would be very happy.
08.05.2020 20:21 # 2
Karacocuk24
Use it carefully, it will be smooth when you go to work.
08.05.2020 20:21 # 3
Cem took the balata spray and put them on a good clean disc. I recommend you to replace the brake hydraulic oil.
08.05.2020 20:21 # 4
CemDemiral
[QUOTE = Karacocuk24] Use with care will be improved. When you go to work, you are on your way to the highway or you are constantly taking off [/ QUOTE]
I am in traffic, I leave my wife to work first, I go from work to work, the same event occurs on the evening.
08.05.2020 20:21 # 5
CemDemiral
[QUOTE = sonerkyl] Cem takes the lining spray and clean the discs with a nice clean. I recommend changing the brake hydraulic oil. [/ QUOTE]
I bought a spray, I squeezed it today, I just did not think of hydraulic, so let me tell you the result.
08.05.2020 20:21 # 6
The brake hydraulic oil of the prediction has never changed. I think next time, change brake hydraulic oil. While my 206 was unchanged, there was some dirt at first. Now the braking response is more of the vehicle.
08.05.2020 20:21 # 7
CemDemiral
The brake hydraulic oil of the [QUOTE = sonerkyl] estimate has never changed. I think next time, change brake hydraulic oil. While my 206 was unchanged, there was some dirt at first. Now the braking response is more of the vehicle. [/ QUOTE]
I looked at the hydraulics at a normal level, but as you said, it seems like it has darkened, I guess it has not changed at all.
08.05.2020 20:21 # 8
TUNAYCAN
friends, I am an automatic gearbox master, call when you have a contract 05545485711
