digital km display problem in the display
08.05.2020 19:12 # 1
razzmatazz
Friends, I dismantled the indicator of my car last night, while the engine of the tachometer was not working, it was stuck to make it complete, the film on the side of the km screen was on the side of the dial, the ribbon-shaped cable was pulled out, it was stuck.
08.05.2020 19:12 # 2
fætih
My teacher is not as before. You can not find any new. You have to go to km repairers ...
08.05.2020 19:12 # 3
koray.turan
I know it's not repaired
08.05.2020 19:12 # 4
Efe-Pojo
As friends say, if you are not knowledgeable about this, or rather, if you do not have the tools to make it, it is impossible to do it. a solder-like precision workmanship is required, you must find someone to do it.
08.05.2020 19:12 # 5
koray.turan
How can the process be applied to the digital region that the adhesive is already
08.05.2020 19:12 # 6
okan77
Is there any tachometer?
08.05.2020 19:12 # 7
koray.turan
The tachometer is going on, I was worried about me. I did the digital region.
08.05.2020 19:12 # 8
fætih
If you take the screen film that I found on ebay, it will be working.
http://www.ebay.com/itm/flat-lcd-connector-for-peugeot-206-sagem-ınfo-display-ribbon-cable-/221737807511?pt=lh_defaultdomain_3&hash=item33a09a6e97
08.05.2020 19:12 # 9
koray.turan
This is the shoulder, but I should get it right now because it's broken
08.05.2020 19:12 # 10
koray.turan
If this product is, I should buy henen, where can I get the installation.
