Digital climate lighting
30.05.2021 18:04 # 1
Bi_ince
Hello everyone, I'm new to the forum.
My vehicle is Peugeot 206 1.4 hdi 2006 model feline package. I have a question for you, the lights of the air conditioner section do not light, there is no problem with the screen light, but none of the buttons are on. I asked the electrician, they said, we need to remove the LED and send it to the brainchild. 500 TL He said that he will keep it around, does anyone have a solution to this or has this situation before?
03.08.2021 14:35 # 2
Bi_ince
Does anyone know 😁
03.08.2021 19:50 # 3
muzzy35
It doesn't work for me either. When I use it, I turn on the ceiling lamp. I think it's hard to remove it, I think it's a tamper with the ceiling lamp ;)
07.08.2021 10:10 # 4
Bi_ince
Look, I never thought of that LOL
07.08.2021 22:57 # 5
omerb
Hello,
While changing the pressure pad, the flywheel gear needs to be grinded or it needs to be replaced with a new one.
I also use the pressure pad. I changed it, then it trembled, because our masters are very moral, he did not say that the flywheel gear should be treated, I showed it to another master and learned.
Re-engineer just to grind the flywheel gear. Need to download.
09.08.2021 09:24 # 6
amatorcul
Mine is 206 cc 2005 1.6 same as mine I don't know
Digital screen lights were not working. I bought 3 of them for 2 TL and replaced them
First, remove the information screen, don't pass. It comes when you hesitate
Then there are two bolts, it comes complete with the tape recorder.
There are bolts on the digital air conditioner screen, remove them, turn the screen diagonally and take it out
There are 3 lamps on the back changing directly.
17.11.2021 02:23 # 7
Bi_ince
Thank you, it's 3 TL, not 500 TL.
