digital air conditioner problem
08.05.2020 19:17 # 1
babel3433
Dear friends, first of all I wish you good forums. I renewed the air conditioner gas of my 206 hdi feline vehicle. However, even though the pipes and records keep ice, hot air blows into the interior. The service filling the veteran said it was related to the brain. Another master said that he did not need to connect to the computer, that it was a malfunction of the flap, and that he had to insert the chest and look. I do not want to make the obvious love go. What do you think could be the source and solution of the problem? Is there any problem between you and the problem? Meanwhile, the vehicle is left in the sun for a long time. In the coolness of the evening, there is no problem in the cold weather. she clicks. I'm waiting for your help.
08.05.2020 19:17 # 2
KILIC
If my teacher blows cool air when you drop the temperature to 14-15 in eco mode without turning on the air conditioner, I think that there is no problem in the flap, and you also have trouble in the sun. By the way, how good it is blowing
08.05.2020 19:17 # 3
babel3433
I haven't tried it in Eco mode, sir. but it gets cold early in the morning or in the evening. It doesn't get cold when it's under the sun in the day.
08.05.2020 19:17 # 4
KILIC
how many degrees you run well
08.05.2020 19:17 # 5
babel3433
I'm running at 21_ 22 degrees. When I do not cool I drop until 17, but only normal air blows
08.05.2020 19:17 # 6
sdttn
There may be an evaporator problem. Piping is undesirable.
Moisture and water discharge may be blocked in the area under the vehicle that corresponds to the air conditioner box.
sdttn 2015-05-18 21:27:18
08.05.2020 19:17 # 7
babel3433
I hope it's not from the evaporator. It seems a very difficult place and costly operation.
08.05.2020 19:17 # 8
sdttn
The drain must be under the vehicle or under the hood, somewhere below the air conditioning line.
08.05.2020 19:17 # 9
babel3433
I will try your suggestions, friends. Thank you for your attention. Problem cozulurse I will share with you again.
08.05.2020 19:17 # 10
cagriaktas
Hello friends, I am new among you..I hope I did not make a mistake by hooking the subject a little old..I bought 2000 model roland 10 days ago..when I turn on the digital air conditioner, the hot blowing in eco mode continues unchanged..and the lowest figure on the screen is 57 is the highest 84. Normally, it doesn't have to be between 14 and 20 odd .. The air conditioner engine is activated in AC mode, the vehicle is slightly shaken but it blows hot..It does not change even if I play with the degrees ... at that moment, it gives the heat inside the vehicle's engine. .. Two days ago, it went to cold mode and the air conditioner started to work ... This time, when I bought eco mode, the normal cool air blew it did not go to the heat. And yesterday, I gave some gas when the engine was idle. It worked for 10 minutes. hot blowing continues. I am new to the forum, I hope I did not make a mistake.
08.05.2020 19:17 # 11
coolhortlak
Q. A friend has a garros in me. On the inside of the car, there is a two-inlet air conditioner filter under the steering oil box inside the hood, there is a metallic gray cylinder shaped two inlet air conditioner filter. He was stuck, cleaned and saved, but if he does not save, I have a price between 150-200tl.
08.05.2020 19:17 # 12
cagriaktas
Thank you very much for your interest ... I'll have a look at it tomorrow ... but is it normal that the lowest temperature on the screen is 57 and the biggest is 84 ...
08.05.2020 19:17 # 13
cagriaktas
Good evening again ... I showed the car .. The valve motor, which is a plastic piece with a plastic similar to the engine and plastic wheels inside the toy car, has changed. The simple piece with a tiny engine is amazed at 330 TL. Anyway, keep in mind friends ..
08.05.2020 19:17 # 14
cagriaktas
good evening friends..klepe engine changed problem solved..three hard plastic parts..that has two blasted plastic wheels.There is a small motor inside.330 tl price..70 tl gas 330 tl flap motor 50 tl workmanship ... Your information
