Difficulty shifting back
08.05.2020 20:35 # 1
x571
Hi
The car changed the clutch set at 118 thousand km 8-9 thousand km ago. he has not done so before. It is difficult to shift into reverse nowadays. 2-3. passing it in the trial or I can do it back after throwing it to 1. What could be the problem? what should i check.
08.05.2020 20:35 # 2
The general problem occurred to me in many vehicles. If my teacher lost the clutch wire feature or something, it might be from him. But if there is no different sound coming from the shaman, don't worry too much, the vehicles that happen to me would be in focus 1 - megan 2 - 206, occasionally I would put 1-2 gear like you and then it would pass directly.
08.05.2020 20:35 # 3
x571
[QUOTE = sonerkyl] General trouble has happened to me in many vehicles. If my teacher lost the clutch wire feature or something, it might be from him. But if there is no different sound coming from the shaman, don't worry too much, the vehicles that happen to me would be in focus 1 - megan 2 - 206, occasionally I would put 1-2 gear like you and then it would pass directly. [/ QUOTE]
There is no other sound from the gearbox, sir. Is there a way to find out if the wire has lost its property? can we have a visual inspection? There is a shortage. I thought he would leave us on the road. sometimes I go 1000 km long road.
08.05.2020 20:35 # 4
Adem Kurtuldu
I do not know the other brands, but something that happens in every peugeot is a normal situation.
08.05.2020 20:35 # 5
mchtaknc
I thought I had only me. I came to my head, it was difficult to shift back into gear when I thought it was passing and I even heard the rubbing sound of the gears.
08.05.2020 20:35 # 6
littlenikksay
I have the same problem, just press the clutch once and let it go
08.05.2020 20:35 # 7
mustafa881
If the clutch cable is defective, the pedal will occasionally remain depressed. I think it may be because the noise in shifting into reverse gear is easier to go back after the 1st gear due to the black gearbox in many cars.
08.05.2020 20:35 # 8
Oktkor
He rarely does it though.
