Different sound like engine sound when 306 engine is loaded
08.05.2020 20:44 # 1
Serhat306
Hello everyone. I have 1999 model 306 griffe. When you are driving, when you press the gas in each gear, you get a different sound like engine sound. When the motor is released from the load, the sound goes away, only the motor's own voice. Especially after 4 thousand cycles
The sound is getting more and more like a moaning sound. What I didn't do is that there are no wedges, axle gearbox bearings all changed, but there was not the slightest change in the sound. No one can find it, they say sell the car, they're crazy. Is there anything like this happening to you?
08.05.2020 20:44 # 2
x571
[QUOTE = Serhat306] Hello everyone. I have 1999 model 306 griffe. When you are driving, when you press the gas in each gear, you get a different sound like engine sound. When the motor is released from the load, the sound goes away, only the motor's own voice. Especially after 4 thousand cycles
The sound is getting more and more like a moaning sound. What I didn't do is that there are no wedges, axle gearbox bearings all changed, but there was not the slightest change in the sound. No one can find it, they say sell the car, they're crazy. Is there anything like this happening to you? [/ QUOTE]
It's hard to say anything without hearing. For 306, 4 thousand revolutions are seriously high and 3500 yells like crazy.
08.05.2020 20:44 # 3
Onur1912
lpg li vehicle?
08.05.2020 20:44 # 4
aykutbayram1996
No worries about sensation
08.05.2020 20:44 # 5
Serhat306
We suspect the gearbox bearings, we opened the gearbox. There was no problem with the bearings, the gears were also in good condition, we changed all the bearings, but there was not the slightest change in the sound.
08.05.2020 20:44 # 6
Serhat306
Yeah. When the LPG setting is tightened, the torque of the engine decreases so as not to be heard.
08.05.2020 20:44 # 7
Serhat306
4 thousand cycles already means 120 km speed means normal highway cruising speed.
08.05.2020 20:44 # 8
lReDl
The same complaint is not left to me. Someone said alternator, changed the bearings inside. He did not improve. Said the strap did not improve. One of them is stripping from the air conditioner, let's put on a little short belt and he will recover. When navigating the timing belt has been lost had he jumped out of the entanglement kasna fied Trigera, after I have already been told.
I forgot the car for the trouble, of course, I ignored it for a while, but the sound has increased. I said your job and rolled up the sleeves. I found that it was caused by the timing tensioner.
Mine was doing it when the car warmed up, not when it was cold. I don't know how.
Heat the car and make noise. Remove both belts. battery will not be charged, headlight etc. not open. Also, since the hydraulic pump is not working, the steering will be very stiff.
If the damn voice is still coming, yours is also from the timing tensioner. I hope you will find a solution.
