different size help ....
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 15:27 # 1
voodoo
friends ii forums first of all, i use it on 195 45 16 sizes now, but i want to change the tires if i put 205 instead of 195 would i have a kite in the hood ?? thanks for the help
08.05.2020 15:27 # 2
metin
If I remember correctly, I think 205/40/16 is the best tire for the 16 "rim in the 206's
08.05.2020 15:27 # 3
cerci07
I have 206 da205 45 16 does not kurt but I do not know if there is a drop in the augers
08.05.2020 15:27 # 4
voodoo
No, do not fall in my augers .... so when you say surtmuycek :) thanks friends tskkurler
08.05.2020 15:27 # 5
Haksen016
only if the width will change, it does not rub, so after 195 to 205, but if the rim grows in diameter, you should decrease the cheek size.
08.05.2020 15:27 # 6
g-demir
you don't mind, it doesn't rub
08.05.2020 15:27 # 7
voodoo
thank you
08.05.2020 15:27 # 8
106_arts
If you drop your car, nothing will happen, but the ideal size for 206 is 195 45 16, but if you raise it, nothing will happen.
08.05.2020 15:27 # 9
oguzhan29
The ideal size is 195 45 16 but unless you play with auger of your car or something, there is no such thing.
