Different operation of the vehicle
08.05.2020 16:58 # 1
t.tuncel
First of all I wish everyone a good day.
I am a user of 99 model peugeot 306 griffe 1.6. Recently, there is a problem that has gotten my head. When I start the car, it seems like a single piston is not working. It gives a sound like a tractor. I have been trying 5-10 times so that they get better and the engine fault light is on, when I take it to the service, they said it was blinking because the vehicle was LPG, and I would be glad if you inform them about where and why it was caused for the last 3 days.
08.05.2020 16:58 # 2
Serkan
Hodja, first of all, you should have a look at the link below.
08.05.2020 16:58 # 3
t.tuncel
Is there anyone who can answer on the subject?
08.05.2020 16:58 # 4
sezar206
As a requirement of the forum, you must first introduce yourself. then friends will help you.
08.05.2020 16:58 # 5
t.tuncel
I thought I had introduced myself in the link given to my friend. Where did I make a mistake?
08.05.2020 16:58 # 6
[QUOTE = t.tuncel] well, my friend thought I had introduced myself in the link given where I made the mistake wrong [/ QUOTE]
No problem, you introduced yourself.
The engine malfunction light can burn from LPG. Dogrudur.
However, if there is an error in a different place, your computer's computer records this error and lights up the malfunction. Since the fault light is already on for LPG, you cannot understand whether it is a new error or LPG. Connecting your best vehicle to the computer and seeing all the mistakes. Errors from LPG will be evident. If your vehicle is 8 valves, it may be time to adjust the cent. Take a look at your car soon. Don't use your car.
08.05.2020 16:58 # 7
t.tuncel
they have tied the computer to the authorized service, they tried very hard, they did not connect to the pc, then they said the connection & nbsp; we did not show any malfunction ... meanwhile, it does not always do it after hard use, as if one of the valves did not work, the service did not find anything, I did not understand anything from this work ... another My question is, let me make the settings of the vehicle to the authorized service system, or can it be done by any master, or is it costly? Thank you very much in advance for your
answers
08.05.2020 16:58 # 8
You do not need to go to the authorized service. You can get it done in any service, but if you don't have a good master, get advice based on your location and go with it. It shouldn't be expensive. Friends who have it will help. In the meantime, if the engine malfunction light was on, the vehicle produced an error record. I think it is not very convincing that they do not see any errors when connected to the computer.
Where do you live? Please write the location information of your profile.
koliva 2012-08-09 11:34:47
08.05.2020 16:58 # 9
t.tuncel
I live in Bursa, I will immediately remove the deficiencies in my profile ... & nbsp;
