Differences between 206 GTI and RC
08.05.2020 17:52 # 1
Thomassee
Friends, what are the differences between these two especially in terms of motor and walking?
08.05.2020 17:52 # 2
Thomassee
Does anybody know Smile
08.05.2020 17:52 # 3
reality59
206 RC;
Engine Capacity: 1997 cc
Motor Power: 130 kW (180 HP)
Max. Power: 7000 RPM
Max. Torque: 4250 RPM
Weight: 1050 Kg.
Number of Cylinders: 4
Maximum Face: 220 km / h
Torque: 210 Nm
reality59 2013-08-14 19:42:01
08.05.2020 17:52 # 4
reality59
206 GTI;
Motor Power: 99 kw (135 HP)
Max. Strength: 6000 RPM
Torque: 4100 RPM
Net Weight: 1100 Kg.
Cylinder: 4
Maximum Face: 210 km / h
Torque: 190 Nm
reality59 2013-08-14 19:44:50
08.05.2020 17:52 # 5
Thomassee
Thank you, teacher Thumbs Up
I wonder if the RC block is the same as the GTI ??
I guess then there is only a chip GTI.
08.05.2020 17:52 # 6
error
tomas ikside uses ew10 engine block, ew 10 is a very stable and solid engine, peugeot used this engine in its entry level performance sports such as 206 gti 206 rc 406 coupe 307 xsi.
It is not difficult to get 180 hp from ew 10 138 hp engine, but it is not just a job with chip, 180 hp can be captured with package processes such as rc intake manifold + port polish + rc throttle + exhaust + forget + exhaust + chip + fuel pump update.
If you say that you have to push the boundaries well, the upper limit is up to your financial power, works on 200 hp on ew10 are available, turbo itb etc etc etc.
error 2013-08-15 10:42:25
08.05.2020 17:52 # 7
Thomassee
It really did.
When I say turbo, custom ecu, hc piston or something, there are 400-500 hp areas.
But the vehicle transfers how much of that power to the wheel.
Despite everything, a beautiful machine is a must.
08.05.2020 17:52 # 8
error
For the ew10, the turbo may not provide very healthy results, but I think this engine block will stay at atmospheric 170 hp when you say how to transfer it to the road. error 2013-08-15 10:34:27
